GOOD TO KNOW THAT THE PROBLEM IS NOTICED, IT IS CLEAR THAT THE FAULT IS EITHER THE CAMERA IS DISCONNECTED OR THERE ITS A SOFTWARE PROBLEM. IF UT IS DISCONNECTED, YIU,,LL HAVE TO CAREFULLY OPEN OND GET IT RECONNECTED.AND IF SEE ITS THE SOFTWARE PROBLEM THEN YOU HAVE TO FLASH THE PHONE. GOODLUCK... BUT YOU HAVE TO CHECK ALSO IF THE CAMERAS COVER IS PROEPRLEO PROPERLY OPEN I MEAN.
easy fix. yo turn it on and then very lightly tap the lens cover or push it out. then you should clean the lens because the dirt or dust on the lens is stopping the lens cover.
ok.under the lens cover there is a small switch which may lose it's place.
to find it remove the batterry cover , remove the two screws on the body of lens cover,then remove the rear cover (plastic and metal-one body) and you''ll find the tiny switch.Put it in a right place to work when lens cover open.
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
CAN'T OPEN LENS COVER
New c902 but cannot open lens cover
I did have the same problem. Same solution worked. I love the internet!
