Question about Lexmark X6170 All-In-One InkJet Printer
Won't Print Color
My printer is showing it has color ink in the cartridge but will not print the ink on the paper. Black works fine. What can I do to fix this?
  • lola_2525 Aug 07, 2008
    I have exact same problem. I tried (and did according to manual) cleaning the head of color ink, still did not work, so installed new cartridge and was SHOCKED when it did not work, either!
    I have made sure it is aligned properly. Soooo, thought, maybe that cartridge was too old, although seal was never broken. Anyway, went to Walmart this evening to buy a brand new color cartridge, but changed mind after I saw the $37.50 plus tax, price tag.
    Computer says the color cartridge is 3/4 full, I have left it in place, figure I ran the 1/4 out doing "test" pages. Test pages did not look right, and half the time gave me 'alignment' errors.
    Problem Solver:
  • 8 Answers
Check and make sure the box for Print all in black; has not been selected for your printer. Make sure the ink cartridge nozzles are not clogged and that the ink cartridge has been aligned correctly. Hope this helps.
Posted on Jul 29, 2008
Ink cartridge cannot be recognized
Are the cartridges you are using remanufactured? Some printers are very picky about this and will only work with manufacturer cartridges. What brand of printer?
Jul 26, 2017 | Epson...
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Jan 24, 2009 | Dell 922 All-In-One InkJet Printer
Won't print in color
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
Jun 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X6170 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
