Question about Panasonic Matshita- | CW-8124-B | USB 2.0 | Combo CD-RW (GPCW8124BU) Burner
How to delet value data from upper lower filters of the key
Hi there
i read your comment on how to fix dvd drive that was not recognising blank disks. you said we need to delete value data from upper and lower filters of the key. i am not a computer guy. i am just following your instructions.
can you please tell me how to find these value data of upper and lower filters?
i can not burn disks because my dvd drive does not recognise empty disks.
i have matshita dvd ram UJ 820s.
  • 1 more comment
  • durand_richa Aug 08, 2008
    can not remove error expert from my scren and i have tryed to delet the file and it want leave
  • JamesH1978 Nov 02, 2008
    what the hell is the lower filters key
  • tekkkfreak Nov 04, 2008
    I have the same problem with matchita uj-841s!
The easiest way to remove the filters is to use the tool that Microsoft supplies at this link. http://support.microsoft.com/kb/314060
Posted on Apr 01, 2009
Windows 7 on a Toshiba Satellite can't detect blank discs, neither CD nor DVD. Other discs it has no problem reading. I tried deleting the upper and lower filter registry keys to no avail.
Did you try running the Windows 7 repair disk? If this does not fix the problem, then try a restore point when the drive was working properly.
Sep 02, 2013 | Computers & Internet
Dvd burner not detecting blank dvd
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Feb 01, 2013 | Acer Aspire Computers & Internet
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
I have dell inspiron 6000 my combo drive is not recognizing dvd format movies although it is supporting cd formate
Hi Fazi1814,
If you're issue is that the dvd drive could not read the cd at all then you might want to try deleting upper and lower filters from registry editor. This files from windows sometimes cause an issue to your drive/
Here are the steps on how to locate and delete them:
1. Open Registry Editor - go to Start then type regedit on start search box then enter
If you get any notification just click continue
2. Once window is open, Look for the following subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10
To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. On the right pane, select upper and lower filter, right click then delete.
4. Click Yes when prompted
5. Exit registry editor and restart the computer
If your issue is that the drive reads the disk but it does not play the movie. This could be an issue with the movie format. Not all movie format can be played by the windows media player. In this case you need to have either of the following: (but I suggest you get both)
1. K-Lite Codec Pack 7.10 (Full) (to be able to read almost all types of movie and music format)
2. VLC Media Player 1.1.8 (can read any kind of format without installing any codec but still recommended to have codecs installed)
You can try downloading this two software from www.filehippo.com.
Hope this works!
Thank you for using Fixya,
avf110686
Apr 05, 2011 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
I have the Same Problem, it can play cd/dvd that are already burn but if i put in a blank it say cant read from this disk
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model.
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Jul 11, 2010 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Drive reports no disk even though a disk is inserted?
Does it do this with all disks - or just one?
If it is all disks, your drive is probably died or dying, if it is jjust one disk, then it could be the disk is faulty.
If it is a blank disk, it could be the wrong format - R instead of a +R, or vice a versa,
If it is only one disk and it is a data disk try using this to recover the data.
If this helped you then please help me by voting kindly, thank you.
Oct 16, 2009 | Computers & Internet
My computer wont read disks it was able to a few days ago and i went to go put in a disk that needs to get installed before i can use a camera. I have tried others disks and it wont read any of them....
You need to first check if the disk is being detected by Computer--
click start---computer ---check if the disk that u insert is visible there or not.
And also chk in device manager---by right click on computer--properties---device manager(vista)--look for cd/dvd drive.
right click on my computer---properties---hardware----device manager(xp))--look for cd/dvd drive.
If not visible in device manager then u have to open up ur computer and reseat the cd/dvd drive cables...
If its visble in device manager--then right click on the option under cd/dvd drive----properties----check for the error code.
If error code 19 , 31 , 32 , or 39 is displayed inside Device Status.
Then click start -- run -- and -- type regedit -- click ok . the registry editor appears.
In windows XP -- click file -- EXPORT-- TYPE A FILENAME THAT IS EASY FOR YOU TO REMEMBER AND CLICK SAVE.
A COPY OF THE REGISTORY HAS SAVED FOR BACKUP PURPOSE.
CLICK THE PLUS SIGN (+) NEXT TO THE FOLLOWING ITEMS IN THE LIST :
In Vista click:
HKEY_LOCAL_MACHINE
SYSTEM
CURRENTCONTROLSET (OR THE CURRENT CONTROL SET WITH LOWEST NUMBER IF THAT IS ALL THAT IS LISTED)
CONTRO
CLASS
SELECT 4D36E965-E325-11CE-BFC1-08002BE10318
SELECT THE UPPER FILTER IN THE RIGHT WINDOW AND PRESS THE DELETE KEY
CONFIRM THE DELETION BY CLICKING YES
SELECT THE LOWER FILTERS IN THE RIGHT WINDOW AND PRESS THE DELETE KEY
DELETE ALL OTHER UPPER FILTER AND LOWER FILTER VALUES WITHIN THE 4D36E965-E325-11CE-BFC1-08002BE10318 KEY
CLOSE THE REGISTRY EDITOR AND RESTART THE COMPUTER ...
This should resolve the issue...
Let me the the error code and msg in device manager window.....
Thank you ....
Nov 08, 2008 | Acer Computers & Internet
Laptop
I recently lost my CD/DVD drive when I (correctly) uninstalled a Roxio application from my Toshiba laptop. After a week of frustration, I finally found the fix. My CD/DVD drive is back!
Go to the Windows START menu.
Click on RUN and enter: regedit
FOLLOW THIS TREE:
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
In the CLASS folder, look for:
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters] You will see the upper and lower filters folders once you get to the end of the tree… *\*\*\control\class
If a backup folder for either the upper or lower filter folders shows up, clear all the data from these folders as well.
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot
Nov 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Dvd drive wont work
That error and a number of other error codes can be reported for a DVD or CD writer if something has damaged one of the filter drivers, which are called Upper Filter and Lower Filter drivers in the Windows Registry. They can be installed by CD-writing software such as Roxio Easy CD, or by DVD players such as PowerDVD, or by programs such as Musicmatch Jukebox.
Microsoft describes the problem in MS Knowledge Base article 314060 - CD-ROM access is missing and messages cite error Code 31, Code 32, Code 19, or Code 39 after you remove Roxio Easy CD Creator in Windows XP at http://support.microsoft.com/?id=314060.
The article applies to Windows XP Home Edition and Windows XP Professional It implies that the problem is caused only by Roxio software, but the error can occur with any type of CD-writing or DVD software. Error messages that may occur when you try to access your CD or DVD drive include:
1. - Windows cannot start this hardware device because its configuration information (in the Registry) is incomplete or damaged. (Code 19)
2. - This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
3. - A driver (service) for this device has been disabled. An alternate driver may be providing this functionality. (Code 32)
4. - Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
5. - Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
However, there are other causes for these and similar messages. The solution provided below applies mainly to CD or DVD drives. For other explanations, read this MS Knowledge Base article - http://support.microsoft.com/?id=310123.
Uninstalling and then reinstalling CD-writing and DVD software may cure the problem, but in other cases, such as yours, the Windows Registry has to be edited in order to fix it. Making erroneous changes to the Registry can render a computer unbootable, so before you edit it, use Windows XP's System Restore to create a restore point that will allow you to restore it in Safe Mode, or export the keys from the Registry editor by using its File => Export feature. For more information, enter the word Registry in the Search box of Start => Help and Support.
Enter regedit in the Start => Run box to run the Registry Editor and click on the + signs to expand and highlight the following keys:
H_KEY _LOCALMACHINE => SYSTEM => CurrentControlSet => Control => Class => {4D36E965E325-11CE-BFC1-08002BE 1 0318}
There should be many keys called {4D36E965E325-11CE-BFC1-08002BE 1 0318}
If you want to export a copy of the values, select File => Export and enter a suitable filename, which will be saved as a .reg file that can be restored just by clicking on it. When you select a particular key, in the right window, for some of them, you should see keys called UpperFilters and LowerFilters. Select each such entry in turn, right-click with the mouse on it, and click Delete. After closing the Registry Editor, you should be able to use the CD/DVD drive again. However, you may have to reinstall software that accesses the drive, such as CD writers and DVD players.
Nov 10, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
876 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
