I've bought a USB 3RCA data cable to project video from my Laptop to me TV/projector. However it doesn't work, and no signal appears to be received by either TV or Projectors... USB 3RCA Cable from PC to TV/Projector. I've searched help sites, and seen that Microsoft recommended Service Pack 2 resolved many of the video driver issues from USB ports, but my upgrade has had no effect... Can you help? Thanks
I have the same problem?????
My computer doesnt even see that iv pluged it in !
I am using vista 32 bit service pack 1.
When i bought the cable it didnt come with a Driver (CD/DVD)
Posted on Aug 24, 2010
    Scholar:
  • 174 Answers
I hope that is a USB driver issue when u plug your device does your computer detect any usb device and then its says unknown/unrecoginzed device. You have to check the cables first then you download USB2.0 driver install it inyour computer andl aslo try to connect the device in another port also put the the driver cd for the TV/projector
Posted on Jul 02, 2008
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Hi how can i connect from my pc's s-video socket to a projector which has a jack socket? I have all the right cables I've been told to press fn f4 but my pc doesn't have fn
If it's a laptop, they've usually got a vga connector on the rear panel which you can use to connect to an external monitor...or a projector if it's got the same (vga) connector. If your projector only has a jack socket, then that's not a standard connector for a video input and maybe you should consult your projector's user guide for clarification of the connectors (are you sure your jack socket isn't actually a phono or RCA socket? if it is, then your laptop video output signal probably isn't compatible with the projector as there's no way to make s-video output feed anything other than a s-video input (different signal levels and standards) Regards, nicam49
Aug 22, 2011 | Computers & Internet
I am trying to hook my notevision projector to my laptop so that i can show a powerpoint. I did not receive a cord with my projector. Which cords will i need? I received a usb to usb and VGA cord but i...
I tend to use the VGA cable. Once connected, switch the laptop on until you get to the desktop, then switch on the projector. Some will see the signal, if not, simoultaneously press your FN and relevant 'F' key to send the signal out to the VGA. You may need to do this 3 times, once to send to projector, one to send back to laptop screen and then once to send the signal to both projector and laptop screen. Sometimes this can take a short amount of time. You may want to change the projector settings to the VGA input so it doesn't constantly search for a source. If you still have problems, go into properties on your laptop and advanced. you m,ay need to unclick the box saying 'Extend to..........' (You should find what I mean from this, I am in front of a pc therefore the settings are slightly different.)
If nothing then works, it may be your video card.
Good luck
Aug 11, 2011 | Sharp Notevision PG-M20X Multimedia...
I would like to connect my my hp laptop to my Sony Grand WEGA KDP-57WS550 57 in. Rear Projection HDTV-Ready Television to watch netflix
You need to connect your PC to either your TV or your receiver. Also, if you have XBox, you can watch Netflix through it (thought I'd suggest, just in case).
Take your PC (or take a photo of your available outputs from your PC) and a photo of your available inputs (on your TV or receiver) to Best Buy or similar computer store. They can help you learn which connections you need.
Most likely you'll need a DVI to HDMI cable for video, and maybe a separate audio cable from your headphone connection on your PC to your TV (or receiver). You'll only need a separate cable for audio if your HDMI input on your TV does not support audio.
I am going through this same problem with my TV connecting Apple TV. I am checking now whether my old rear projection tv's HDMI input supports audio (same as yours). I've connected Apple TV to my rear projection TV. I have video, but no sound. Either my TV doesn't support HDMI audio, or I need to change a setting on the TV to enable that sound to work. If the TV does not support HDMI audio, I will need to connect Apple TV directly to my receiver via a digital optical cable for sound.
Hope this helps.
Jun 22, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
I am trying to project a presentation from my toshiba laptop to a Hitachi data projector (new). The desktop and all have a red/pink tinge. i even tried just going into my pictures and doing a slide show -...
This sounds like a bad cable... do you tight the scew? inspect the cable connector at each ends to dbl check that there is no damaged pin, and also on the projector side...
Oct 15, 2009 | Computers & Internet
Connect the USB to 3RCA cable from computer to TV
what TV model you have? maybe it is not on the right connection / setting
The PC must have the dual monitor mode in order to work as well what PC model you have .. specifically the video card /.... ensure that the video settings are set to TV mode as well for the default monitor
Oct 06, 2009 | HP Computers & Internet
Cannot connect laptop to tv using 7pin 3rca s-video cable
eon your laptop keyboard there might be a button you push to change the display output on mine i push Fn F7 It has two screens on it and when i use this it lets me output my display to other devices
Dec 30, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
429 people viewed this question
David Payne
David Payne
