Question about Garmin nuvi 350 GPS Receiver
Garmin Nuvi 310 !
Hi
Is there any equipment/system to charge the Garmin Nuvi 310 on a normal house socket as opposed to via the laptop or car lighter?
Please let me know.
Regards,
Anisa Vahed
Email: anisav@dut.ac.za
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Didn't you get a wall charger when you bought it?
    Scholar:
  • 174 Answers
Yeah, garmin sells that too check here
https://buy.garmin.com/shop/shop.do?pID=1344
Posted on Jul 30, 2008
How do I recharge the battery on my Garmin Nuvi 255WT? I would also like to know how to update my Garmin?
Recharging the battery is done by connecting the nuvi to a vehicle power cable in the car through the vehicle power accessory outlet or cigarette lighter.
The unit can also be charged via a powered USB port off your computer via the USB power/data cable or an AC power adapter through the USB power/data cable.
Aug 15, 2011 | Garmin nuvi 255W GPS Receiver
How do I charge it for the first time?
You can charge it by connecting to your cigarette lighter socket in the car for 4 hours, or you can charge it with a mains charger for 4 hours. The mains charger normally has to be bought seperately. Or you can charge it by connecting it to your computer for 8 hours with a mini SD card.
Mar 26, 2011 | Garmin nuvi 1450 GPS Receiver
Nuvi will not charge when plugged into car charger but will charge when plugged into house charger
  1. Check that the cigarette lighter socket is working. If not it may be a fuse blown in the fuse-board.
  2. In the charger plug, that goes into the cigarette lighter there is a fuse which may be blown. At the tip of the plug you'll see a ring. On most chargers it's silver but some are black. Unscrew the ring and the plug will come apart. Take care not to lose the small metal tip when you open it. Replace the fuse. If there's power going to the charger and this fuse is replaced your problem should be solved.
Dec 17, 2010 | Garmin Nuvi 770 Car GPS Receiver
Battery
The unit will take a very slow charge via your computer. I tell most people no it doesnt charge VIA your PC just because it takes soooo long. I recommend getting a new power cable from GPSCity. Just call them up or follow the like to the cable you need.
** This cable is for the Nuvi 200 series GPS units
http://www.gpscity.ca/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi-in-web-packaging.html
Cheers
Jul 13, 2010 | Garmin nuvi 260W GPS Receiver
Hi, just plugged device in pc via usb to charge from new, logo came on ok so left it a while. on checking after half hour or so, i realised i hd stupidly forgot to plug my laptop into the mains, the...
somthing like this happened to my garmin nuvi, i pluged it into a car charger the logo came up then it went away, died for ever...
call garmin to check to see if its still under warrenty.good luck
Feb 04, 2010 | Garmin Nuvi 255 GPS Receiver
My garmin charges with my computer but stopped charging in the car
The most obvious answer is a possible blown fuse in the cigarette lighter socket or the in the tip of the charger plug. Most charger plug fuses are accessed by unscrewing the metal tip. Check both for good fuses.
If this doesn't solve the problem, make sure the points of contact between the charger, cradle and GPS are all free of dirt and grime. Don't forget to vacuum the cigarette lighter socket - especially if it is used as a lighter, too.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
The cradle no longer charges the garmin in my vehicle. It's not charging anymore. Nuvi 750
Sometimes, if the Garmin GPS battery is allowed to fully discharge, it would require charging directly via USB cable connected to a PC or Mac before it would accept a charge for the cigarette lighter again. Try connecting this way for 4 - 8 hours or more before going forward.
Check the cigarette lighter plug in another "known good" lighter socket / vehicle to help rule out a defective socket. A socket without power indicates anything from needing to change a "simple to replace" fuse - or a bigger problem - damaged wiring in the vehicle (if the socket is used to light cigars & cigarettes - vacuum the socket out to remove ash and tobacco that may collect inside). Trying the GPS elsewhere helps eliminate possible problems with the socket. If it doesn't work elsewhere, depending on the plug that goes into the socket, it too may have a built-in fuse. Check the plug for an exposed fuse - or see if the tip unscrews to provide access to a fuse inside. If unsure, the tech Support people at Garmin are a great source for free help.
Lastly, dirt or grime on the "cradle to GPS" connection or "cable to cradle" connection could be causing the failed connection. In short - carefully inspect all points of connection and remove any deposits found.
Sep 16, 2009 | Garmin GPS
When I attach my garmin nuvi 760 to the car mount and plug it in the car charger it will not power off and on when the car turns off and on. For example if I turn the car off the garmin continues to charge...
This is telling me that your cigarette lighter socket has +12VDC applied to it all the time EVEN when the ignition is turned OFF. This is not the fault of your Nuvi. On some cars, like Hondas, the cigarette lighter socket powers off when your ignition is turned off.
If you want it to turn off with the ignition, then you will have to power it from a +12VDC source that is controlled by the ignition.
- Jim
Dec 04, 2008 | Garmin GPS
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
Don't work with the cigarette lighter connector
Check if you are able to charge other devices via the cigarette lighter such as a cellphone or try to use the lighter if the light does not get as hot as normal then that means that there is not enough power. If that looks ok then try another cable charger for your Nuvi
Aug 09, 2008 | Garmin 010-00358-00 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
83 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
