Question about Toshiba 42H81 42" Rear Projection Television
Problem with TV screen?
The image on my TV's screen lately seems too big for the screen itself. It cuts off some of the image on both sides.
  • 927 Answers
Good Day, deon453;
Sounds like a convergence problem.
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Posted on Jul 10, 2008
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
Image is cut off
Use picture menu and adjust screen resolution or size.
Feb 02, 2013 | Panasonic CT-30WX54 30" TV
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
Projected image is too large for screen
Good Day Brian;
The warped, too large picture is the same problem, the TV has a convergence problem. ln today's electronics the first thing that should be done on any electronic device is to, reset, unplug TV from the a/c outlet for at least 4-5 minutes then plug back in. If no fix; Your TV has a circuit problem. RCA has three common problems that could cause this condition; the most common is a fuse near the fly-back, IH-VT, the convergence power board or the signal board.
Always, call a factory authorized service dealer if you are not familiar with repairing electronic equipment that contain HIGH VOLTAGE, just for your own safety.
Jun 21, 2008 | RCA Televison & Video
Picture went out on Akai
I have the solution.  Call me  910-8936663
Oct 15, 2007 | Akai PT5492S 54" Rear Projection...
Xbox 360 screen cut off on left side
Ok, I've had the same issue and I was able to fix my problem. I was getting cut off sides in HD mode on my playstation.
I entered the service menu by doing this:
Turn TV Off
Use remote and hit "Mute 1 8 2 Power" (not at the same time, but one after the other)
The TV will come on with the service menu. Enter the 1080i adjustment screen. Write down ALL the values in case you mess up. Adjust the values as necessary to fit your screen. It's sort of like adjusting a computer monitor's image for different resolutions.
Hit me if this helps... mlager at sysnosis dot com
Sep 20, 2007 | Samsung TXN3071WHF 30" TV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture seems to fall off the screen.
Julie,Did you by Chance have a Projection tv down stairs,If so Contact you Cable Company for Proper Settings......
Jun 22, 2007 | Sanyo DS25390 TV
Screen Problems
Has the TV been dropped lately? If so it's possible the coils that guide the electron beam are misaligned. Also many tv's (same for computer monitors) have either manual knobs or firmware controls that allow you to position your screen and adjust height, width, etcetera..
Dec 28, 2006 | RCA T19408 19 in. TV/VCR Combo
Toshiba 42H81 42" Rear Projection Television Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
