Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Red flashing light and no channels on Daewoo DS608P
Blinks red light then with sound for a couple of second, then turn off by it self no light on the projectorlens
Posted on Oct 07, 2008
Dock red light
Flashing Red Light is not charging and solid red light mean charging the radio battery.
Dec 09, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
L dont have right 4-digit code for daewoo, the codes i have,dont work
Try these codes.
0130 0004 0009 0100 ................. 0005 0138 0043 0140 0039
....... 0252 0279 0444 0080 0042 0058
....... 0017 0010 0126 0018 0127 0019
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method.
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 17, 2012 | Televison & Video
THE IMMOBLISER IN BY DAEWOO IS CAUSING PROBLEMS IT WONT START IN THE MORNING TAKE GOOD 10 MINS TO GET THE RED LIGHT ON THE DASH BOARD TO STOP FLASHING AND WHEN I TRY TO START THE CAR THE RED LIGHT IS BOLD,...
look for large wiring loom under steering column that is patch harness going to immobiliser module,
two black large connectors that look the same disconnect and isolate connect original loom connector from top to bottom body harness original connector and presto no more immobiliser its bypassed vehicle now works.
Sep 07, 2011 | 2002 Daewoo Lanos
What is the remote code for daewoo tv's
Hello
Three digit universal remote codes for Daewoo TV are:
004/ 005/ 009/ 017/ 018/ 019/ 042/ 058/ 082/ 083/ 085/ 097/ 100/ 126/ 127/ 130/ 138
Four digit codes are:
0130 0004 0009 0100
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK.
Aug 15, 2011 | Daewoo Televison & Video
Need code for my tv
Hello
Three digit universal remote codes for Daewoo are:
Four digit universal remote codes for Daewoo are:
0130 0004 0009 0100
Direct Code Entry
Thanks for using Fixya.
Mar 22, 2011 | Daewoo Televison & Video
Setting Radio Channels
press and hold the button you want to designate for the station you want to program...hold until the screen flashes or beeps at you...you're done!
Good Luck
Jun 14, 2009 | 2001 Daewoo Leganza
Daewoo ds608p cka not picking up a signal have scanned several times but not finding any channels?
I have not resolved the problem i am waiting for you to come back to me! I was given the option of signing up for the premium plan which i declined so presumably i will not get the free advice offered?
Aug 29, 2008 | Televison & Video
I have a Daewoo DS608P Freeview box which will not detect any chennels. The pre=scan and scan appear normal, but nothing is detected. The TV, which has no Scart socket, works fine on analogue, and I have...
Sorry to be the bringer of bad news but the transmission mode in the uk is changing & that is why your box will not pick up any channels have a look on http://www.freeview.co.uk/help/faq/id104963 I'm affraid your box is finnished.
Jul 25, 2008 | Televison & Video
No channels can be detected have tried 2 Daewoo DS608P boxes connected to same telly but same thing happens. Signal strength seems fine boxes have been working fine for years.
I am the same. Not a sausage from my same model Daewoo freeview box today. Scans and re-scans and not a single channel to be detected.
Rob
Jul 05, 2008 | Televison & Video
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
