Question about Compaq FS 7550 17" CRT Monitor
LG CB553H monitor has power and menu that sais no data. When I connect to a pc there is no display.
    Brigadier General:
  • 6,966 Answers
A monitor display showing "No Data" indicates that either the PC is not sending any usable video signal or the monitor is not capable of displaying the incoming video signal. To determine which is at fault, you would need either a known good second monitor or a known good second PC.
Additionally, it is also possible that neither is at fault and that you simply need to lower down the Screen Resolution and/or the Screen Refresh Rate of the computer's display properties to match the limitation/capability of the monitor. A method of verifying if this is the case is to start the PC in "Safe Mode" by pressing F8 after POST before Windows boot.
Alternately, there are some instances that it is the video cable that is the issue. To verify, you can try wiggling the cable to the connector end that goes to the PC's Video output.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
Have lg monitor flatron e2260 . Have had for about 3 weeks. Starting today, the monitor goes black and states "d-sub power saving mode". The tower stays on. Thx
1. Check the connections and make sure they are still tight. If the monitor isn't getting data signal it can go into power saving mode. Since it was working I would check this first.
2. Look in control panel under POWER OPTIONS and make sure it's not set to turn off after so long.
3. Also check the settings for your screensaver under display settings. That too could put it into poewr saver mode.
It could be a setting on the monitor itself that somehow got changed. Check out the settings to see if anything has changed.
Apr 21, 2011 | LG Computers & Internet
My monitor has gone blue, what do I do
Assuming the monitor is powered (if unsure, check the that power cord is connected to a live 120 volt source and the other end is connected to the monitor), check the data (analog VGA or DVI) cable between the monitor and the computer. Make sure the connectors are firmly seated in the respective jacks, and held in place with the retaining screws where provided.
If all four connections (power in and out and the data in and out) are satisfactory, check your monitor's input "source" selection. This may be selectable via dedicated "Source" button on the monitor or from the monitor's "Menu".
When changing the source input types with the button, it will usually take a couple of seconds before an image will display, so allow enough time for the monitor to respond to the change. If changing via menu selection, it may not change until saved or exiting.
If the monitor refuses to display, it may be an issue with your video card. In this case you could try swapping the video card or the monitor to determine which is the culprit.
I hope you found this Very Helpful and good luck!
Nov 17, 2009 | LG W1934S-BN 19" Monitor
After starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Aug 28, 2009 | LG L1915S 19" LCD Monitor
"power saving mode"
Have you connected and then power on PC? does this monitor works any other PC? Is old monitor works in your PC? Some models of monitor has menu functin from what type of connector use to recieve data but they also automatically adjast it. Try to find if your model has any. If PC works in others and all connections is all right its better to bring your monitor back to shop.
Aug 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor not displaying any thing but green linght is on
Ok on that case your monitor is going bad and you just need to throw it out however if it is a new monitor then take it back to where you bought it and tell them what's going on. If you need anything else please let me know!
Apr 08, 2009 | LG Studioworks 77M Monitor
Fluctuating display when processing data in my PC
Does it mean that text, or any data found in your monitor has a shadow? There is nothing wrong which kind of system your using (xp, linux) it is on the monitor. It is on the mixing of color, the repair man/technician knows how to adjust those things.
Thanks
Nov 19, 2008 | LG Studioworks 700S 17" CRT Monitor
My new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Oct 05, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Fuse blown repeatedly on CB553H-KL
Re your post/description on an LG CB553H-KL fuse blowing, this is indicative of an over current (>5Amps) flowing through the AC mains supply. If you are comfortable doing component level repair and familiar with electronic parts/circuitry, continuity tester and a soldering iron, please do passive (off-board) test of the following components:
D900 - bridge diode;
C908 (150uF/400V) - filter/power capacitor;
Q901 - regulator.
If Q 901 is shorted, pls likewise check ZD901, D910, R902 & 915.
Just to be sure/safe, check also:
C901, 902 & 904;
TH 901 & 902;
Though unlikely, you may want to check also:
Q706 - Horizontal out transistor (attached to the aluminum wall acting as heatsink;
FBT - Flyback transformer.
Other than the component aforementioned, no other parts would cause enough current flow to blow the fuse. But of course, anything can still be wrong
Hope this be of some help. Pls post back how things turned out or should you need additional information.
Nov 16, 2007 | Compaq FS 7550 17" CRT Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Compaq FS 7550 17" CRT Monitor Logo
97 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
