Question about Canon Office Equipment & Supplies
Replacement of the waste ink absorber PIXMA MP 110
    Sergeant:
    Champion:
  • 248 Answers
Not a user replacable part. must be handled by a qualified technichian. very sensitive part. call pixma and get a service center in your area.or visit
http://www.canon.com.hk/en/Consumer/Product/ProductDetail.aspx?product_id=10167&series_id=10024
Posted on Jul 02, 2008
    Genius:
  • 1,847 Answers
So what is issue with printer, can explain more
  • Legin Varghese
    Legin Varghese Jul 02, 2008
    Turn on your MP110.
    After that press: Menu - Scan - Copy - Scan.
    It will enter in Service Mode.
    Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
    Resetting the Waste Ink Volume Counter
    1) Enter SERVICE MODE.---
    By pressing Menu-Copy-Scan-Copy-Copy
    2) Select TEST MODE.
    3) Select [8] PRINTER TEST in TEST MODE.
    4) Select 3. [EEPROM CLEAR].
    5) Select 0. [INK COUNT].
    6) Press the [OK] key.
    7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Need to find the waste ink absorber in a pixma mp 130/110
There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Closethe lid and the printer should now function normally.
Jun 26, 2011 | Canon Office Equipment & Supplies
Pixma MP 130/110 Printer/Copier/Scanner waste ink absorber full, It neither prints nor copies
Cleaning the waste ink pads is easy.
Are your ink tanks empty and have you been using non Canon cartridges?
Regards,
Worldvet
Aug 01, 2008 | Canon Office Equipment & Supplies
HOW DO I REPLACE MY CANON PIXMA MP 110 WASTE INK THANKS VERY MUCH
Replacing is not the only problem, Canon didn't make any parts available for that machine and there's no way to reset the error code.
Dec 04, 2009 | Office Equipment & Supplies
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Jul 01, 2009 | Office Equipment & Supplies
Conon waste ink absorber full how do you replace
canon mp 150 series printer USB 001 The waste ink absorber is full
May 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
May 16, 2009 | Canon Pixma MP450 All-In-One InkJet...
Cartridge jammed / Waste Ink absorber almost full
Waste ink pad or pads are full and need changing.
Under your ink carraige cradle it is,
It will be full, bit of a dirty job.
Hope this helps
Ric.
Apr 17, 2009 | Office Equipment & Supplies
Waste ink absorber is almost full
Try this:
Resetting overflow error code for Printer Canon Pixma MP110
  1. Turn on the printer.
  2. Click Menu, and then Scan, Copy and Scan again. All - entered the service mode.
  3. Select Counter
  4. Click Copy - everything. Waste dropped to zero.
  5. Turn off the printer POWER button.
Good luck
Oct 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
old marine
old marine
