2000 Jaguar S-Type Logo
Anonymous Posted on Jul 02, 2008
Jaguar rear window removal
How do you remove the left rear window of an s-type jaguar
  • 2 more comments
  • julieh04 Sep 28, 2008
    Rear driver side window has dropped of mechanism. Need to remove door panel to get to window. How do you remove the door panel.
  • onebluefrog Nov 15, 2008
    Can you please share the solution about this problem.
    I tried to remove the door panel, but is too hard, I‘m afraid to damage it. Thank you.
    -onebluefrog
  • Anonymous Jan 17, 2009
    how
  • EDDIEMORR Jan 17, 2009
    how do you remove the rear window so that I can renew the electric window
    regulator rail on my jaguar s type 1999
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1704
Points
6
I followed the instructions given by your expert Richard.His instrutions were clear and precise,and I had the problem solved in 5 minutes.best regards A.Taylor
Anonymous
Level 1:
  • Posted on Jul 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1704
Points
Need to remove door panel on S type passenger door
A
Anonymous
Use a house brick, throw it from 5 feet, voilla. job sorted
A
Anonymous
2 Related Answers
Anonymous
  • Posted on Mar 15, 2011
SOURCE: S Type Jaguar rear bumper removal
how do you remove a front bumper off of an jaguar s type?
Anonymous
  • 420 Answers
SOURCE: S Type JAguar Rear Door
First remove all of the screws, some will be hidden under plastic caps, then take a door panel tool (about $5.00 at a parts store) and work it around the panel popping out the plastic keepers. Be carefull and try not to damage the panel where the keepers attach, you can buy new keepers at any auto part store and even Lowe's and Home Depot carry them.
9helpful
3answers
2003 Jaguar S type fuel filter location
Remove the left front wheel and remove the securing nuts to the wheel arch(plastic wheel well liner) pull back from the rear and you will see the fuel filter under it. Thanks.
Jaguar fuel pump assembly schematics are needed
YOU CAN REMOVE THE FUEL PUMP FROM THE TRUNK AREA REMOVE THE TRUNK LINER REMOVE TRUNK SEAL RETAINER AND THE REAR LAMP ASSEMBLY INTERIOR TRIM FINISHERS AND REMOVE LEFT AND RIGHT SIDE LINERS.
1helpful
I have a 2002 jaguar s type but for some reason my rear left window is not going down when i press button do anyone one knows whats going on?
Vibration can cause connectors to come apart. You will have to remove side panels to inspect. Could be a bad motor.
1helpful
Jaguar s-type window motor problem
Rear window glass is held in by a retaining 2 part pin. use a punch to knock out plastic 2 part pin out of center window regulator window plate.
4helpful
Rear window regulator line broken
Hi lec the rear glass has a white plastic clip holding the glass to the regulator. try from  the door side, pushing the center plastic pin out toward you then the glass will lift out   D
Rear window regulator s-type jaguar
Likely will have to replace the regulator that rolls the window up and down
S type
remove door panel adjust window so you can see the mounts the window is attched to remove screw's/ bolt's lower window lift up at angle and pull out slowly don't hit glass on edges will break .
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
