Question about Performance Teknique ICBM-779 Car Audio Amplifier
Performance Teknique wont work!!
I have an ICBM 779 Performance Teknique amplifier that went out on me..i was swithing it to mono mode since one of my subs was blown..as i was disconnecting the bad sub i accidentally made contact with the sub..i was playing music..not loudy..but it made a spark and my amp wen out..i tried re-wiring everything and it won't work..is it repairable if so how??..
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
If you want to try to repair it yourself, read through the following page:
Basic Amplifier Repair Primer
Let me know if you have any other questions.
Posted on Jul 02, 2008
How good is this amp?
It's an alright model for getting good treble sound out of.
Apr 15, 2010 | Performance Teknique ICBM-779 Car Audio...
Icbm-892 amp performance teknique on protection mode
see what the volts and uf are and u can desolder the old one with some solder wick and find a replacement out of some old junk electronics that is the cheapest way I have done this many times and the used one does not have to be black
May 07, 2009 | Performance Teknique ICBM-892 Car Audio...
ICBM-DIGITAL MONO-Channel 2000W AMPLIFIER speaker much
Look into competition lines of different manufacturers.... Massive Audio DMX, Soundstream, Atomic APX, Incriminator Audio Death Penalty Series, Kicker Solo X etc. In car audio, you have to pay to play. Dont expect a 100.00 subwoofer to take 2000W continuously.
Massive Audio offers a no questions asked warranty. Even covers blown voicecoils!
Dec 21, 2008 | Performance Teknique ICBM-Digital Car...
Performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Sep 10, 2008 | Performance Teknique ICBM-896 Car Audio...
You may have a defective speaker or a wiring fault. Disconnect the speaker from the amp and measure the resistance across the speaker wires. The resistance should be near the rated impedance of the speaker.
Jan 27, 2008 | Performance Teknique ICBM-779 Car Audio...
Icbm 779
If there is significantly less bass even though the speakers are moving approximately the same as before, you may have one speaker wired out of phase. Disconnect one speaker. If the bass increases, double-check your wiring.
Nov 17, 2007 | Performance Teknique ICBM-779 Car Audio...
Performance Teknique ICBM-9550 Amp Problem.
one of the power transistor of your unit shorted check use a tester
Aug 27, 2007 | Performance Teknique ICBM-782 Car Audio...
Performance Teknique ICBM-779 Car Audio Amplifier Logo
408 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Joe Alexander
Joe Alexander
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
