Question about Whirlpool Washing Machines
F06 DRUM DOES NOT SPIN PROPERLY - Whirlpool Washing Machines
What is f06
Posted on Feb 23, 2009
Whirlpool awod error f06 flashing. how do i find it.
tacho feedback error...the sensor for the drum is not picking up the speed of the drum
Mar 25, 2017 | Kenmore Washing Machines
Error code F06 and E01
Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
F6 CODE ON WHIRLPOOL WASHER
F06 -----Drive motor tachometer error
the control is unable to properly detect motor speed and the machine will shut down.if a failure occurs during high speed spin the door will be unlocked after the drum has stopped rotating.
POTENTIAL CAUSE
check the harness connections between the motor and ccu
check the tacho circuit on the motor
check the motor resistance winding
Dec 10, 2012 | Whirlpool 8182697
I am greeting a flashing code of F06 as in goes into spin cycle and it stops running.
The F06 code will indicate a drive motor tachometer error.This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
The error code F06 is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling a service technician to check the connection.
Hope this helps.
Shane
Apr 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F06
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool Washing Machines
I have this written in my machine F06 what is that meanning
Hope this helps.
Shane
Mar 15, 2011 | Whirlpool AWM8143 Front Load Washer
F06 message
Hi
Thanks for using FixYa. Error F06 in your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 error
F06 Error
will shut down. If a failure occurs during high-speed spin, the door will
be unlocked after three minutes.
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Aug 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
198 people viewed this question
Dan Webster
Dan Webster
Sal De
