Question about Medion MD 40812 Notebook
Power Options -Medion MD 9783 notebook
I am at a loss with this one!-My battery(ms 2111)seems to loose charge after about 20mins unplugged. I have checked my m/c out (as far as I can) & everything else seems ok.Charging light-on--fan running,--time left monitor--etc seem ok.
Could you advise me of the best power option settings as it may be that I am entering in-appropriate hours (like tun off monitor after?
turn off hard discs after?) -so--
can you please give a sample set of settings that I can try?
Thank you for reading this and I eagerly await you response Joe.
  • Anonymous Jan 31, 2009
    i cant find this laptop's driver. can you help me?
  • 12 Answers
I have a Medion laptop as well.....unfortunately, this is just a cheap battery. Mine can be fully charged, but will only last 30 minutes even if it's just sitting on the desktop. You can try changing your "performance" settings (hold your cursor over the battery icon in the taskbar, it should give you an option change "power plan"). Choose a lower power-consuming power plan (note, lower-power consuming plans won't let games, etc run right). But, ultimately I think you'll find it's just a bad battery that won't hold a full charge anymore.
Posted on Feb 19, 2010
Charging battery
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
Dec 07, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
I have a 1997 ram 1500 with charging issues. Replaced the alternator and it still will not charge, took it to a shop to have it scanned, they said the PCM was bad, they changed the PCM and it still will...
charge rate should be 13 to 14 volts, if you below that it is probably a weak alternator. be sure to check all wires and cables to the battery and starter. The starter is part of the charging system an loose connection can make weird stuff happen. As far as shifting check electrical connector to trans. if it is unplugged or bad connection PCM can't tell it when to shift.
May 25, 2012 | 1997 Dodge Ram 1500 Club Cab
Loss of power& at times stalls Fuel pressure
LOSING POWER WHEN RUNNING COULD BE LOOSE BATTERY CABLE.FAULTY ALTERNATOR.NOT CHARGING BATTERY.CHECK BATTERY VOLTAGE SHOULD BE 12.6 VOLTS.WITH ENGINE RUNNING ALTERNATOR POWER OUT PUT SHOULD BE 13.5 - 14.5 VOLTS WITH ENGINE RUNNING IF NOT ALTERNATOR BAD.CHECK ALTERNATOR BATTERY FEED WIRE CHECK ALTERNATOR VOLTAGE REGULATOR WIRES AND CHECK ALTERNATOR FUSE AND MAKE SURE DRIVE BELT NOT LOOSE.BESURE TURN OFF RADIO BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOSING RADIO CODE.
Mar 05, 2011 | 2000 GMC Jimmy
Describe your 99 ford expedition the battery light turns off and on and then the battery started and loss charge. The truck battery was so lo that the lights turned off. Now the truck wont start its dead.
Possible that the alternator is faulty , the charging section of the voltage regulator charger is faulty, finally there is some heavy shorting in the circuit or a possible poor ground connection from the battery to the chassis.
You will need to charge the battery and recheck once again to confirm , check the charging voltage and check the drain.
Find this link useful:
http://www.fixya.com/cars/r5824824-draining_car_battery_charge
Feb 19, 2011 | 1999 Ford Expedition
Suddenly cut off after lossing electrical power on all inside lights and gauges. also has low charge. is it the alternator or battery? also the o2 wire is disconnect
there may be a short on the battery (most likely) yet you can get it checked for free at any local (national chain) auto parts store they will check both at no charge to you and offer replacements remanufactured alternators usually they have in stock.
May 21, 2010 | 1998 Saturn SL
My battery light came on and at the same time the power steering seems to have gone out.
SOUND ALTERNATOR NOT CHARGING.CHECK FOR LOOSE - SLIPPING OR BROKE ALTERNATOR BELT.CHECK ALTERNATOR ELECTRICAL WIRES FOR LOOSE OR BROKE CONNECTIONS.ALSO CHECK ALTERNATOR FUSE.IF EVERYTHING CHECK OUT GOOD SO FAR.THE ALTERNATOR IS MORE LIKEY DEFECTIVE.BEFORE REMOVING NEGATIVE BATTERY CABLE TURN OFF RADIO FIRST SO YOU WONT LOSE CODE.
May 20, 2010 | BMW 328 Cars & Trucks
Cause of MS-1036 loss of power?
Try taking the battery out and see if it will fire up just with the adapter. Please don't take your unit apart unless you have some experience in this procedure.
Dec 03, 2007 | MSI MS-1036 Barebone
Medion MD 40812 Notebook Logo
796 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
