Question about GPS
How do i do a hard reset on my hp ipaq rx5900 gps. its frozen
  • Anonymous Jan 03, 2009
    My GPS on my rx5900 does not seem to work. I have tomtom on my Ipaq and it is not loading any Maps Where could i find an answer
    Brigadier General:
  • 6,966 Answers
To my knowledge, there is a reset hole along with voice record button and an SD/MMC card expansion slot on top of the unit. Use the stylus to lightly press the reset button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
My ipaq 2750 has frozen on ProtectTools screen. I have activesync installed but it wont even recognise the cradle device
There's a chapter called 'Resetting your HP iPAQ' on your device's User Manual. Firstly, perform a soft reset. If it doesn't solve your problems, jump to the hard reset procedure. If it still doesn't do the job, then, perform the clean reset procedure.
Just in case you happen to miss its manual, you can download it from this location.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 23, 2010 | HP iPAQ HX2750 Pocket PC
My Hp ipaq h1940 pocket pc is frozen on the hp opening page with 2 1.07 at the top I have tried soft and hard reset and removing the battery.
check HP support for a rom update for your model. the h1940 had some problems you are having.hope this helps
Jul 16, 2009 | HP iPAQ H1940 Pocket PC
Rx5915
I got this info from HP website..
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
The HP iPAQ restarts and powers on
It doesn't mention a password. I also have an HP Ipaq and don't need a password to hard reset. Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 | HP iPAQ rx5915
HP iPAQ hard reset
Scroll down on this page to find the ipaq 5000 series:
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
(H5450 and H5455 are the same ipaq)
Jul 25, 2008 | HP iPAQ H5455 Pocket PC
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
My HP rx5910 froze!!! Please help...
i did a hard reset and now i have the same problem. i was working just fine before the hard reset, i wonder why i did that move. Don't do that if you think it's a solution.
May 27, 2008 | HP iPAQ rx5910 GPS Receiver
I have a hp Ipaq h2200 pocket pc
Hello :-) I have a Ipaq 4350 and the same thing happened to me. one day I hard reseted it and when it came to the point when it asked me to align the screen it froze and wouldn't move at all. I found out that it was screen that got damaged somehow. And I think your screen is damaged too. I'd recommend calling HP.
Apr 10, 2008 | HP iPAQ H2210 Pocket PC
Frozen screen
hello :-) i just talked to another person who was having the same problem as you. And guess what?? the same problem happened to me on my IPAQ 4350. It turned out when I would hard reset my IPAQ it asked me to align the screen but it wouldn't move and it would freeze and not let me pass . But I later found out that my screen was damaged and I got a new touch screen installed and my IPAQ works perfect :-). I would recommend for you to do the same and call HP and see if they could install it for you. Thanks :-}
Nov 05, 2007 | HP iPAQ H2210 Pocket PC
Hard reset
Hi I confirm that the following works
I would say
-- pressing calendar (1st) + Itask (last) buttons + reset button does a soft reset and fully disconnect the battery (you will a click sound
-- pressing calendar (1st) + mail (3rd) + power + a reset button does a full ghard reset. You will see Formatting PS... on the screen. This means every is back to factory defaults.
Thanks twosix for this post
Sep 09, 2007 | HP iPAQ HX2790 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
GPS Logo
163 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
