Question about Compaq Netelligent 3612 (267007-001) Networking Hub
Netwoking problem how i can do networking from laptop with window vista to desktop with window xp by a hub/switch
  • 118 Answers
Try This.
By useing"strait Network cable" connect your both system with switch/HUB.
Now You may need to provide the IP addresses manually on your both systems. (procedure of providing IP manually is also mentioned below)
like on PC # 01 it can be Sub net:
on PC # 02 it can be sub net:
after providing these address you can access your system in this way ....
!.. Go to the RUN in start menu
2. Type IP address of you required system with "\\"
for example if you want to access PC # 02 you will type "\\" (with out commas)
Dont forget to share the required drive on your HOst System.
I am also giving the steps to provide manual IP adresses..
Configuring a Static IP in Vista Click on the start orb to open a list of programs and content. The start menu has been replaced by the “start orb” which still gives you the same functionality as the start button from previous OS versions, but consumes less screen real estate.
Right click on “Network” and go to properties. That opens the “Network and Sharing Center” which is your central office for anything pertaining to (just as it says) networking or sharing resources.
On the left hand column you want to click on “Manage Network Connections.”
This opens the Network Connections Window which you will find familiar to Windows 2000/XP. It will list all of your NICs or Wireless Connections.
Right click and go to properties of the connection you would like to statically assign. You will now be prompted for an administrative password. This is part of Microsoft’s new User Account Control (UAC) which will help unauthorized changes to your systems.
Once you have authenticated you will see the properties of the selected network connection.
The properties screen is very similar to what you’ve seen in the past, but one thing you will likely notice is by default Windows Vista supports IPv6.but you will select Internet Protocol Version 4 (IPv4) and click properties. Now you will be able to enter in your IP, Subnet Mask, Default Gateway, and DNS addresses and click OK.
Close the Network Connections Window and you’re running with your new IP.
1. Go to Start > Connect To > Show all Connections.
2. Choose your connection (In this case I selected my Wireless Connection), right-click on it and select Properties.
3. A dialog box opens, make sure you are under the General tab, select Internet Protocol(TCP/IP) from the list , and click on Properties.
4. Make sure to click on Use the following IP address and fill out the information for your computer. Click OK.
Let me know if it helps...
best regards,
Tanveer Ahmad Khan
Posted on Dec 02, 2008
  • 86 Answers
Computer names as to be same workgroups either windows XP or Vista & ip segment as to be same.........
Posted on Jul 09, 2008
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Drivers for Win 7?
It is likely that you are attaching the docking station with a laptop running Windows 7 OS. In this case you should visit the Kensington Europe website and download and install the latest software version of K33926 Kensington Universal Notebook Docking Station with VGA/DVI and Ethernet Software for Windows 7, Vista, and XP (5.2.22372.0) Note that this is a combo software that includes the drivers for both the video and ethernet.
Apr 28, 2010 | Kensington (1500100) Networking Hub
i think you should take the admission in a network related Certfifcation LIke CCNA by Cisco.
Dec 02, 2008 | Compaq Netelligent 3612 (267007-001)...
Netgear switch fsgo5v3
well, apparently your switch is taking off your PC from his arp table due to his inactivity.
try to release and renew the ip address in your machine instead of reset the switch.
Normally reset the switch will be you last resource.
go to START -->> RUN type cmd <hit ENTER>
a black windows should populate, its calles command prompt.
ipconfig /release
then ipconfig /renew
this will force the switch to see your network Interface Card.
Dec 01, 2008 | NetGear FS605 (FS605SE) Networking Switch
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Connecting 2 PCs Via the D-Link Hub
Hi Ajog,
Those Ips look good. Make sure the Subnet on both is Since they are both getting to the internet, I assume the Gateway IP is correct.
On the, got to Start>Run and type in CMD. A black window will open, and type in PING You should get four responses. If you don't, you probley have a firewall issue.
Do that same on the machine, back to the machine.
On the XP machine, follow these instruction, just skip down to Step 9.
Vista gets a little tricker, but not bad. To setup the network on the Vista machine, go here, ad click on the Network icon.
Great link to save to your desktop!
Using the network wizards should setup your firewalls to allow File and Printer Sharing.
Good luck
Jan 08, 2008 | D-Link DE 805TP/C (DE-805TP/C) Networking...
Compaq Netelligent 3612 (267007-001) Networking Hub Logo
149 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
