Have moved my Sky to another room. Cut existing sat cables and extended to new location. Can watch all stations OK. Can record OK. When recording I can't watch any other station. Any ideas what I've done wrong?
Originally used pre made "F" connector to "F" connector cables from B and Q.
Have changed above cables to the thicker black ones - same size as comes of sat dish.
This solved the problem - suspect attenuation problem by using inferior cables.
Posted on Jul 03, 2008
I WANT TO BE ABLE TO SEND SKY TV SIGNAL TO ANY ROOM, i HAD THIS IN OUR LAST HOUSE BUT CAN NOT REMEMBER HOW i RUN ALL THE COAX CABLES. i HAVE AN APLIFIER IN LOFT WHICH CABLES TO EACH ROOM, SO DO i NEED TO...
put coax from sky box output then into splitter in loft ampifier and conect all other coax that run down to other rooms to the outputs in amplifrer and turn on sky and put menu on then tune tv's in on anolog station
Dec 20, 2009 | Panasonic TH-42PX60U Television
Dish dvr reception keeps cutting out
Hi mikej10x! I will be more than glad to assist you in this concern. You mean, intermittent signal? If that is the concern mikej10x, lets isolate the problem, 1st check the sat in 1 and sat in2 if the cable is connected tight, as well as the separator, diplexers, all device that is connected to the line of sat in, then press the power button on the front panel of the receiver for 10secs, receiver will turn off and then turn on by itself, then attention 015 will pop up on the screen, then press the menu button right away once you see the attention 015, then main menu will show on the screen and once main menu is up, press 6,1,1 on the remote control and it will go to the point dish screen, select check switch on the upper right and it will go to installation summary screen, select test on the bottom of the screen and it will run a test up to 2 of 2 or depends on the sat you have, once its done it will show the installation summary, sat input 1 & 2, port1-119-ok, port2-110-ok, once you see that all sat is ok, select done and it will go to point dish, select done again and then cancel all the way out and it will pop up attention 015, let the progress finish until it download the programming guide. the picture will show. observe if problem still exist. if the problem still exist, call 1-800-333-3474 ask for tech support and once you talk to a live agent, ask for a service call, there is a problem on you sat dish system, it could be the lnbf, switch, or the separator or cable connection. or it needs to re aligned the dish.. but before you call, check first if there is no trees or leave blocking on the dish to the southern sky, no obstruction.. please feel free to get in touch if you have any query.
Sep 07, 2009 | DISH Network DVR-625 DTV Receiver /...
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Our Dvr will only record on the channel we are watching. I cannot watch one show and record another? It says I have to be watching the channel I want to record?
for the dual tuner, if you are unsure what this is... please look at the back of the satellite box and see if you have 2 sat in cables. if you do, then you need to reprogram your satellite. if you do not have 2 sat in cables then you would need to contact dtv to get this installed.
Mar 29, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Moving tv to another cable outlet
I f you have cable at the new location follow it back to a splitter. Remove the one you used to use and screw in the one you want to use. They should all terminate at the same location.
Jan 17, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Adding tv to a dish network dvr
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Dec 24, 2008 | DISH Network ViP622 DVR DTV Receiver /...
My sky tells me that i'm not receiving a signal
Check the Sat cable. If the cable is ok , then the antenna had been moved and lost its orientation.
The antenna must be moved until it reaches the right orientation, call Sky and ask them to send a technician to do the job, or do it yourself at your risk.
Oct 06, 2008 | Televison & Video
How to extend the range of my MN-700 Base Station
Hi Entry Level Extenders (or by their real technological name Repeaters) are chipset dependent and therefore guaranteed to work with Hardware of the same Brand. You can try to build your Own Extender. Buy two Access Points (AP) one of them has to be able to be configured as Client. Configure the client AP to communicate to the MN-700 and then plug the second AP to it and configure it as a regular AP. Put the concoction in the middle of the way between the MN-700 and the destination computer. Doing such an arrangement might cost a little more, and be a little bulky. On the other hand it would not cut the bandwidth into Half as Repeaters do. Otherwise may be this can Help. Extending Distance: http://www.ezlan.net/Distance.html Wireless Bridging: http://www.ezlan.net/bridging Wireless Segregation: http://www.ezlan.net/shield.html
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
