Windows cannot load device driver (code 39) in "device manager" there is a sing(!)near Lexmark 2500.the lexmark scaner has stopped working.
  • joelouis Jul 05, 2008
    I'VE DONE WHAT YOU'RE INDICATING MANY TIME BEFORE AND AFTER I WROTE YOU AND...........NOTHING.
    THANKS ANYWAY.
    Sergeant:
  • 287 Answers
Uninstall any software that is specific to the printer/scanner.
You may need to delete the device from device manager then download the latest driver from HERE, and install it
Then reinstall any required software, ensuring youy DONOT install the old drive from the CD. You may want to check the Lexmark website for updated version of ant apps you are using with the device too.
Posted on Jul 02, 2008
No communication between computer and printer
There are a number of issues that could cause a communication problem with any USB printer (assuming it is turned on/has power). The most likely is a bad cable. After that, you need to check for a problem with the OS print spooler, a problem with the port (on either the computer or the printer), or a driver problem.
Replace the cable with a new one. Connect it to a different port on the computer. If you use a print server or a USB hub, try a direct connection.
Look at the list of what is printing. In Windows, open the printers control panel (click Start > Device and Printers or Printers and Faxes, depending on the OS). Then right-click on the printer and choose "See what's printing". Are several print jobs still in the queue? Try to clear these jobs by cancelling them. If you can't cancel them, you can force the print spooler to clear by stopping and restarting the service. In Windows, open the command prompt (Start > All Programs > Accessories > Command Prompt (with Vista or Win7, right click and choose Run as Administrator)). Type "net stop spooler" without the quotes and followed by enter. Then type "net start spooler" again without the quotes and followed by enter. After you see the prompt, restart the computer. After the restart, wait a while before trying to print again. (Note: if you have a fax connected to the computer, you will see a message about the fax service being stopped after the first message. Click Y.)
If the printer status is unknown, check the device manage. Click Start > Control Panel > System and Security > System > Device Manager (in Win7). Right click on My Computer and select Properties then click on the Hardware tab for XP. Look for a yellow exclamation point in a triangle next to Lexmark. Unplug the USB data cable and then uninstall the Lexmark software. (A quick link is the Uninstall link in the Lexmark folder in the list of All Programs from the Start button.) Download the correct driver from Lexmark http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X1270&focusedTab=DOWNLOADS#1 . Select the correct OS from the drop down menu. Install the software and then plug in the data cable when prompted. Alternatively, let Windows find the best driver by plugging the USB cable with the trouble-shooter. Right click on the appropriate line in the device manager. (This is not recommended with all-in-ones since Windows often only finds a printer driver and omits the scanner functions.)
While you are in the Device Manager, check for a similar yellow exclamation point or red x in a triangle in the section marked Universal Serial Bus. Try to update the driver for the USB controller (again you can right click on this).
Next try to reset the printer by removing the data cable and then unplugging the power cord from the printer. Then unplug the power cord from the outlet. Wait a few minutes (if possible, move to a new outlet). Then reconnect the power cord and then the data cable. Turn on the printer if it doesn't come on. Try printing.
If possible, try installing the printer on another computer. If the printer still doesn't work, the USB port on the printer is probably bad. If it is under warranty, contact Lexmark. Otherwise, it may be better to replace the printer instead of repairing it.
I hope this helps.
Jun 12, 2012 | Lexmark X1270 All-In-One InkJet Printer
This device cannot start. (Code 10)
HI
A Code 10 error is generated whenDevice Manager can't start the hardware device, a situation usually caused byoutdated or corrupted driver A device may also receive a Code 10error if a driver generates an error that Device Manager doesn't understand. Inother words, a Code 10 error can sometimes be a very generic message indicatingsome kind of unspecified driver or hardware problem. Uninstalling and then reinstalling the drivers for the device is alikely solution to a Code 10 error. If reinstalling driver is not working than try to rollback the driveror restore the system on previous date.. ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 07, 2011 | Lexmark International Lexmark X422
This device can not star (code 10) help me! thank a lot!
HI
A Code 10 error is generated whenDevice Manager can't start the hardwaredevice, a situation usually caused byoutdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Inother words, a Code 10 error can sometimes be a verygeneric message indicatingsome kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is alikelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driveror restore the system on previous date..
regards
sandy fixya
Aug 17, 2011 | Lexmark International Lexmark X422
Printer say's "please load paper in auto
This could be a printer driver problem. Try to uninstall your existing Lexmark X4270 printer driver from your computer. On your computer, go to Start menu > Programs > Lexmark 4200 Series > Tools > Uninstall. After the process, reboot pc when prompted.
Check if your Windows 7 is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the links below to re-install the printer driver on your computer: - Lexmark X4270 Driver for Microsoft Windows 7 for 32-bit - Lexmark X4270 Driver for Microsoft Windows 7 x64-bit
Jul 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
Webcam does not launch , lexmark x422 driver exclamatry mark show , means driver fail , how to solve this problem , i want to get picture , and use skype video calling
HI
A Code 10 error is generated when Device Manager can't start the hardwaredevice, a situation usually caused by outdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. In other words, a Code 10 error can sometimes be a verygeneric message indicating some kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is a likelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driver or restore the system on previous date..
regards
sandy fixya
Jul 21, 2011 | Lexmark International Lexmark X422
It gives code 10 error. device can not start
HI
regards
sandy fixya
Jul 18, 2011 | Lexmark International Lexmark X422
Webcam not working in dell inspiration n5010. lexmark x 422 error code 10 is displaying in devicemanager.
HI
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted driver A device may also receive a Code 10error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error. If reinstalling driver is not working than try to rollback the driver or restore the system on previous date..
regards
sandy fixya
May 30, 2011 | Lexmark International Lexmark X422
I have connected "Lexmark E323 " printer to my p
What Version of Windows are you running. update driver for your os at Lexmark,com
May 25, 2011 | Lexmark E323 Laser Printer
Hi! i just want to ask about how can i resolve this. it says that lexmark x422 cannot start. code 10 error. please help me solve this problem. thanks!
HI
A Code 10 error is generated when Device Manager can't start the hardwaredevice, a situation usually caused by outdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Another words, a Code 10 error can sometimes be a verygeneric message indicating some kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is likelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driver or restore the system on previous date..
regards
sandy fixya
Feb 03, 2011 | Lexmark International Lexmark X422
Trying to download a driver for a Lexmark Z600
http://support.lexmark.com/index?locale=en&userlocale=EN_US&productCode=LEXMARK_Z605&page=recommendedDownloads&segment=DOWNLOAD#1
Oct 29, 2009 | Lexmark Z600 InkJet Printer
Computers & Internet Logo
42 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
