Question about Kenmore 24032\24036 Top Load Washer
My washer wont drain
I have the hose connected to the sink pipe to drain but the washer wont.
i have had the pipe drain directly into a big container and everything is fine, the problem is when it connected to the pipe on the sink.
any sugestions
Either your pipe to sink is clogged or nearly clogged or the pump on the washer is about to give out. Does the water spray out vigorously when using the container, or does it just flow out?
Posted on Jul 09, 2008
Can only run washer on small load,anything bigger,water just runs out drain.Small loads are killing us,its an extra load,top washer
Check the position of your drain hose in the pipe or sink. It's probably too low relative to the washer tub fill level. You need to make sure that the end of the hose is higher than the maximum fill level of the washer tub. (The pump in the washer can push the water up to 3-5' higher than the washer. So if you have the hose connecting to a drain pipe, it should be at least 3 1/2-4' high if the washer is on the floor. If you have your drain hose directed to flow into a sink, you may need to raise the sink or put a pipe into the sink to raise the drain hose. If you add a drain pipe, you'll need to make sure it won't shift when the washer pumps out the water.)
I hope this helps.
Feb 10, 2015 | Washing Machines
Tip
Clothes Washer won't stop filling with water?
If your washer continues to fill with water and does not overflow onto the floor where is that water going???
The water is siphoning from the machine as fast or faster than it it filling. This is caused by one of two situations both have to do with how the drain hose is routed.
The most common is that the drain is too low. The drain for your washer must first rise above the height of the tub or highest water level before it enters the house drain or drainage sink. This height is typically a minimum of 30". So if you are trying to drain the washer into a low pipe, a short sink or down hill you must first raise the hose or piping to that 30" before it heads down hill.
Second cause is where the drain hose is pushed too far into the house drain. A typical drain pipe in the home has a water trap at the bottom. If you put your washer drain hose down into the pipe too far and contact the water in that trap you will also siphon the water from the machine. The drain hose should hook and be secured to the drain pipe and go inside about 6", that's all that is needed.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
ODOR http://www.fixya.com/support/r4621314-odor_from_towels_or_clothes_washer
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
DISHWAHER WONT COMPLETELY DRAIN ALL THE WATER OUT AFTER WASH CYCLE. JUST CHANGED OUT SINK FROM DOUBLE TO SINGLE.
drain hose is to low to sink connection zip tie side connected to sink up towards bottom of cabinet top so water dosent backflush into dishwasher from sink draining
Jan 27, 2011 | Maytag EPIC MFW9700S Front Load Washer
My washer wont pump out the water
try ur pipe that goes underneath ur sink 2 make sure its not blocked
May 06, 2010 | Hotpoint First Edition FEW10P Front Load...
Washer will not drain or spin with pipe in specific washer drain but will if placed in the sink We have moved house and the new house has the usual pipework behind the washer. The machine will fill and...
Hi.
ok Did you say the drain hose was placed on a spiggot underneath the sink???
the appliance is obviously working as you have tried the drain hose in the sink.
You may find, if you unscrew the drain spiggot, there is a blanking cap. your previous owners put this in place to stop a huge water leak when using the sink
remove cap, refit hose and it should work ok.
Please let me know if I was right?
regards
aardvark Repairs
Nov 18, 2009 | Hoover Washing Machines
Hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Water backing up into washer when not in use
If water is getting into washer when not in use, then I would assume that the washer outlet pipe is connected to your sink waste outlet, this being the case, then this is the cause of your problem
What is happening is the washer outlet hose is below the bottom of your sink outlet pipe, and each time you empty the sink, some dirty water is syphoning back into the washer.thus causing the smell.
The solution is to raise the washer outlet hose above the bottom of the sink and waste pipe outlet so that the water cannot drain back into the washer.
It would be a good idea to remove the pipe from the washer where it fastens to the sink waste, and clean the connection of muck etc'
Plz rate my solution.
thanks.
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How long can drain run be
no the pump cant handle the extra length in the hose
Aug 25, 2008 | Malber WD1000 Front Load Washer/Dryer
Handyman has fixed outflow hose directly into plumbing under sink... since then the water is outflowing as soon as it is inflowing???
call your "handyman" back ..he has created a siphoning problem either drain is too low and/or the hose from washer is fitting too tight in drain pipe ..line must be min height usually about the height of top of washer tub also must have air gap between washer drain hose and the standpipe it goes into like 1 in line into 1and a quarter in standpipe
Jul 31, 2008 | Maytag Washing Machines
Washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
Jul 12, 2008 | Kenmore 46462 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
43 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
