Question about Belkin Computers & Internet
Belkin F5D8633 router - connected wireless to two laptops, two iphones and a printer. After working for a while, first one then the other laptop stops access to the web. The signal is showing strong but comes up with a message "limited or no connectivity". All the relevent lights are 'on', on the router.
    Sergeant:
  • 287 Answers
Are you running XP? have you made any changes to the router or the laptops recently?
Limited or no conectivity suggests that the IP has not been renewed. Have you tried rebooting the Router and the laptops?
Right click on the "wireless" icon in the botton right of the task bar and select status and then select the support tab. What is the Address type and IP address shown?
Try pressing "repair"
Posted on Jul 02, 2008
My iphones and tablet are unable to join on my belkin wi fi why
Go ahead and do some investigating. Does connecting via wired LAN brings any results? Could it be that you're having 2.4GHz interference? Try switching your WiFi channel or moving your router away from large metal objects. If that doesn't work try connecting to your wireless network holding a device close to the antenna, inches away. Does this work? If so, your antenna or WiFi signal amplifier circuit could be dead. You can open your router up and do some further investigating with a multimeter, but if you suspect a hardware failure, it's probably best to not bother opening it up and checking up on your warranty options. Even if that doesn't work out, it's not like routers are super expensive these days.
Feb 22, 2013 | Belkin Surf N300 Wireless N Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to...
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
Mar 15, 2011 | Belkin (F5D5231-4) Router
Belkin router will not connect to iphone
Follows steps to Fix iPhone won't connect to Belkin Routers by Belkin router technical support expertise team. Dial +1-800-335-8177 toll-free to Belkin router error codes and messages.
Mar 21, 2010 | Belkin (F5D7231-4) Wireless Router
Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
Sep 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
