Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet...
I have to run a "clean" operation each time I switch on the printer before the colours are correct.
I have changed all the cartridges and have tried all of the suggested fixes in the manual.
Can you help please????
  • johnandmay Jul 02, 2008
    Thank you.
    I suspected this may be the problem
    Novelist:
  • 121 Answers
What do you mean by "clean" operation? What ends up being wrong with the colors? Does the printer print with the wrong colors?
Posted on Jul 02, 2008
  • Canon Master
  • 13,433 Answers
The print head may be failing, you would have to send it in for service for a checkup.
Noting wrong with your cartridges its the unit that is controlling them. They 'fail' eventually and cause this.
Got warranty? maybe they will fix it for you free.
Check with canon or your dealer.
Thanks,
Ekse
Replaced ink cartridge- still not printing! help
When the printer is not indicating you need to replace a cartridge, and it is not printing good, most of the time the print head is clogged. Run the head cleaning program several times and if that still not works, remove the cartridge and put a drop of clean water or printer cleaning fluid fall in the nozzle, you see down where the cartridge was seated.
Then print a few pages, with the colour that would not print and continue till you see the colour come back again.
switch a ink jet printer on at least once a week. During startup the printer will perform a cleaning cycle. After a few minutes you can switch of the printer. This could keep the front heads clean for a long time.
Success
Mar 23, 2015 | Epson Expression Home XP-410 Small-in-One...
Cannon S330 Printer was operating correctly, print cartridges required new. cartridges changed, will not print, after a time then would print black only, after more time colour began to print for several...
Sounds like your print head may be faulty. If you can, get it replaced. This is caused by using recycled cartidges or faulty ink cartridge.
Thanks,
Lolita
Jun 12, 2008 | Office Equipment & Supplies
Color ink is coming out blue
That means the colour cartridge has failed, as only one of the three colours are working. Try running a head cleaning routine, that may clear it, but don't do too many as it will use up all of your ink.
You may need to replace the colour cartridge. The following YouTube video shows you how to change the cartridge.
Canon MX410 Changing the cartridges
Feb 25, 2015 | Canon Pixma MX410 All-In-One Printer
I have just changed both the colour and black cartridges in my Lexmark X6570 printer. The printer acknowledges that there are full cartridges but when I aligned the colour all that was printed was grey -...
Silly question, have you inserted cartridges in their right compartment?
Id yes!, To save yourself time, suggest you remove printer prog and reinstall latest update from Lexmark, rememeder to leave printer switched on while setting up
May 24, 2011 | Lexmark X6570 InkJet Printer
Changed ink and now the printer wont print
The old ink has probably dried, plugging the jets. Try going through the cleaning cycle (several times if necessary). If it begins to print at all then let the printer set overnight and try cleaning again.
Fred
May 09, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can't print photos with correct colours. Photos in .jpg format and I know colours on screen match colours when printed commercially. Printing from Zoom Browser or Canon Easy Photo gives much worse results...
First clean the print head and run the test print and then the alignment setup to make sure that the printer is clean and registers correctly. In the Printer Properties (Right click on the printer name via Control Panel - Printers) there is an option tab for Colour Management. Click this and select the source that you need to match the print output to. Also go through all the other tabs in Pinter - Properties as there are many setup options there to setup and tweak the colour balance and adding effects etc. This can be quite a lengthy process but well worth the effort. There is no shortcut to doing this but you will end up with a precisely calibrated custom printer setup that you can save and reuse at any time. I have these profiles defined for my printers for each media type and each ink supplier although I have minimised the number of profiles by now using 1 bulk ink supplier to get consistency between cartridge changes and CISS refills. Note that this may vary when you change print carts or change the media type and manufacturers.
Oct 07, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon S520 printer colours not correct
i think its time you replace/refill that ink cartridge. some of the colors must have run out.
Sep 06, 2009 | Canon Pixma iP6600D InkJet Photo Printer
I have used my iP1300 with no problem until it ran out of ink and now the red is very orange and the whole page is faded. I have run a head clean, is there anything else I can do?
Hi - try this. Get cartridges into centre of printer - turn power off by pulling the power lead out. - (dont press power button as cartridge may head back inside - a no no.)
Remove all cartridges, then remove print head by lifting the arm to the right of the printhead. Carefully blot dry all ink showing top and bottom of the printhead with a lint free 'paper" - the stuff they make baby wipes out of is ok as it does not fall apart as does paper tissue.
Wash the print head under warm very clean running water until all colour stops running from top and bottom. Blot dry from time to time to check the clolour is finished. When it is so, make sure all of cartridge is DRY then replace in cartridge holder and close right arm down.
Replace ink cartridges, close top lid and power on again. You should check you cartridges are the correct colour ie not purple or orange etc before reinserting them - else you will have the problem again.
Go into maintenance mode and run cleaning on all colours - this will flush ink thru all heads. Do a nozzle check and it should be all pretty good.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Tri Colour cartridge inserted is not intended for use in this printer msg
Try to clean the print cartridge contact points with a good rubber eraser and clean the printer side cartridge contacts with good lint free cotton cloth. Then first insert Black cartridge and then colour cartridge. Use some more pressure while attaching the cartridges.
Apr 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
70 people viewed this question
old marine
old marine
