Question about BenQ FP91G (Black, Silver) 19 inch LCD Monitor
Blank LCD screen
I have a LCD screen that wont fire up. I believe the green light shows up that it is on but nothing on the screen. It is not the computer as I have another screen on there now and it works fine. I have had someone look at the screen and he has said in only comes on very faints, thought it might be a "globe". However, Im not sure LCD's have them. Is this common and/or worth getting fixed?
    Brigadier General:
  • 6,966 Answers
The description "comes on very faint" is indicative that the backlight is not turning on. The backlight as the name implies provide the illumination of the rear panel of the LCD display. It is made on 1 or more CCF Lamps (cold cathode florescent lamps) and are powered by an inverter that provides the high frequency high voltage needed for the CCF lamps to work. Since the entire screen is dark and it is highly unlikely that both or all the lamps would go out at the same time, it would highly be likely that the inverter is the culprit being the common denominator to all the lamps.
Should you venture to perform a DIY (do-it-yourself) (with the necessary precautions and safety in mind), look for a board that would have small transformers and have connectors that leads to the CCFLs. They often go bad because of dried up/blistered capacitors, cold solder or a general failure in the electronics.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
My sansui hdlcd1955e i can turn it on but it goes blank it still shows the green light on but it wont let u do anything i try to chagne the chanle but it wont let u
Only a green screen is a bad symptom. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen shots to defective LCD panels are given. You can compare it to that of your TVs'.
May 11, 2014 | Sansui HDLCD1908 19 in. LCD TV
Trouble shooting
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Apr 05, 2013 | ViewSonic Computers & Internet
Sanyo dp42848 turns on but blank screen
Replace the Main board if your not hearing any audio from the set.
Oct 27, 2012 | Sanyo DP42848 LCD TV
My acer is not coming on ,there is power going into my lap top but the screen is completly blank?
Bring your laptop under sunlight. If you look very closely and can see your screen then your backlight went out. Otherwise there might be a loose/broken connection to your lcd.
Jul 03, 2012 | Acer Aspire 5535-5050 Notebook
MY ACER LAPTOP 5535 WHEN SWTICHED ON, I CAN HERE THE FAN STARTED AND GREEN LIGHT SHOWS, BUT THE SCREEN IS BLANK, NOTHING DISPLAYING PLEASE HELP!
is sounds like the lcd display may be bad. try plugging a rgb cable into your laptop and another monitor to see if you get pic.
Aug 30, 2010 | Acer Computers & Internet
My monitor won't come on, the green light blinks, but nothing shows up on the screen at all. i've already changed the video card but that did not fix it. prior to changing the video card, once in a while...
try shining a light directly on the screen to see if youve got a backlight failure, if you have there will be an image on the screen but nothing lighting it from behind thus making it seem blank, if that is not the case id start with the vga cable and work from there
Sep 26, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
RCA L32WD22 Screen Blank, Green Light on
in the power supply you have six
Electrolytic capacitors you have to take the cover off the power supply to get to them. 3 of them will be 1000 uf @ 16v and the other 3 will be 1000 uf @ 35v the tops of them will probaly be bulged up replace those and that should solve your problem. you can replace all 6 with 1000 uf @35v and get them at radio shack for $1.79 each.
Jan 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Blackberry pearl 8100 blank screen & green blinking light
Try performing a hard reset: remove the battery from the device while it is still powered on, leave it out for 30 seconds, then reinsert.
Sep 28, 2008 | RIM BlackBerry Pearl 8100
BenQ FP91G (Black, Silver) 19 inch LCD Monitor Logo
184 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
