Question about Dymo LabelWriter 400 Thermal Printer
Dymo 400 Not Printing
I have just successfully installed a new Dymo 400 on my XP system. It won't print. Am I meant to change any settings or should it just print with default settings on installation. I am using standard size labels. Please help.
  • 2 more comments
  • ahood Jul 11, 2008
    Just installed dymo l/writer 400. It printed one label then stopped, now wont print anything at all. Have uninstalled/reinstalled driver and also tried deleting printer.
    When I press print, the error message appears from the printer
  • Anonymous Aug 16, 2008
    Yes, i'm having the same problem. The strange thing is that I have been using my Dymo 400 for about 6 or 7 months now with zero problems. Starting yesterday it suddenly stopped working. It wont print anything and my printer status says "Error - Printing". The printer is being recognized properly. I tried uninstalling and installing the software. Nothing seems to work.
  • sfdif Jan 23, 2009
    I have just install my new Label Witer 400 on my windows computer but i can't print. Dymo label witer computer is connecting with my computer but, I can't print something.
    I had uninstalled and install again but I have always the same problem !!!
    Can you help me to resolve this problem? Thanks!
  • ShaneDP Mar 14, 2009
    Exactly the same here, now onto my third 400 having sent back the other two to Dymo, this one still not working although recognised by the PC. Extremely frustrating. Anyone know the solution?
SOURCE: New labelwriter 400 turbo will not print under windows 2000
I had the same problem and accidently discover it was something very simple...at least in my case. I noticed the power cord connection was very good.. I notice the light on the transformer (cord) was sometimes green then it would go out. When I unplugged and then put some force into reconnecting the printer worked. Hope that helps.
Posted on Oct 06, 2008
tom19511
  • 1601 Answers
SOURCE: DYMO LABELWRITER 400 TURBO
Here is your manual. It will show you what you need...
http://download.dymo.com/media/UserGuides/DLS77Manual.pdf
Posted on Feb 07, 2008
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
  • 14 Answers
SOURCE: Dymo labelwriter 400 Turbo -We replaced the roll
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Posted on May 06, 2010
My Dymo LabelWriter 400 is printing vertically. How do I change it to print horizontally? Thanks
Hi Kaylene, i`ve experience that before.. Just set the print set-up/ preview into horizontal.. The dialog box of print preview will show you the position of your text before printing Dymo Label! goodluck!!
Feb 07, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo label writer 400 turbo will not print
Uninstall the software and disconnect the printer from your PC. Then reinstall version 8 of the Dymo Software (without the printer connected) and connect the printer when prompted by the software.
Make sure you are using version 8 of the dymo label software - it is compatible with Windows 7.
Apr 24, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO Label/Writer is not printing after replaceing labels
DYMO labelwriters use patented labels, anything else would not be recognised by the system. For help - call DYMO support from your country.
DYMO support
Apr 03, 2009 | Dymo LabelWriter 400 Thermal Printer
My Dymo LabelWriter 400 Turbo stops printing after it has printe
Did you change the number of copies to print prior to printing?
Jan 16, 2018 | Dymo LabelWriter 400 Turbo Thermal Printer
Print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
Oct 30, 2008 | Dymo LabelWriter 400 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Just changed labels to 99010 and can no longer print
Did you change the label type in the printing preferences?
Apr 07, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo 400
Disconnecting power and re-connecting will work, but only temporarily.
In order to fix, you need to upgrade the printers firmware...
Windows...
http://www.dymo.com/media/Software/LabelWriter_Firmware_Updater_Rev_AG104.EXE
Mac...
http://www.dymo.com/media/Software/LabelWriter_Firmware_Updater_2.zip
Oct 17, 2007 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
476 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
