Question about Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop
SOUND PROBLEM there is no sound coming in my system.there is no speaker but sound card is builleten. before i was hear sound with earphone but now this is not possible will you please tell me what to do
  • 43 Answers
Check your speakers?? connect it to the green port at the back.
Posted on Jul 02, 2008
I can not hear any music oor use my headfones but all the volume settings are up and reset how do i make it work
I don't know which windows you have but there kind of alike when it comes to test the sound card. In the control panel, open the sound applet and you can see if the sound card shows and then test it.
If you can hear a sound coming from the speakers then test the earphones. If OK then run anti-virus.
Sep 13, 2014 | Naxa Electronics Craig Electronics...
No sound from my laptop?
If you have no sound, there are several reasons. First, the sound may be turned off. Check the sounds icon in the control panel. Check to see if your laptop speakers are the default playback device and make sure they have not been muted. Check the little picture of a speaker in your system tray. Click on it to see if the volume is too low or the little mute square is not checked.
Rarely is the problem defective speakers--rather it's muted volume or the wrong playback mode being chosen. For instance, if you have a set of earphones and you can't hear sound from the speakers, you probably will be able to hear it through the earphones.
Apr 09, 2012 | E-Machines Computers & Internet
Can't make a call do to no sound everything else works but, no sound. I plugged earphones in to listen to music and when I unplugged it I know longer could hear phone calls or when I dial the phone.
Mark, the issue with your phone is with the speaker. This has been confirmed by you when you say the there was sound produced when you used earphones.
You have to get your speaker fixed. Get it done at a local repeir store aroud you.
But in the meantime you could use the earphones for your calls so you can hear them.
But you may still have an issue- hearing your in coming calls- so if you can get a bluetooth headset, that you can hang around your ears, you would hear the calls coming in.
I hope that was helpful to you.
Have a lovely day.
May 27, 2011 | LG CHOCOLATE VX8500 Cellular Phone
No sound from my stereo but powers on and can see EQ is moving. But when I plug my headphones in i get sound just nothing from the Speakers
Your problem is in between the speakers and your earphone jack but it has a hight chance that the fault is in the earphone jack.
Since when you plug your headseat, sound is coming out, this is an indication that your output IC is working. When you plug the headset the line will cut-off through your main speaker to hear the sound in the earphone only. But if you unplug the headset the contact will back to the main speaker. The problem is, the lead is dirty due to dust. You can spray it using the contact cleaner. I will not advice you to spray any penetrating oil but contact cleaner only. If the symptom is still there then this is the time to replaced the earphone jack with a new one.
Hope it may help you.
Have a nice day.
Thanks for using fixya.
JDVillanueva
Jan 31, 2011 | JVC HX-GD8 CD Shelf System
No SOUND
If it has an earphone jack try to hook up your headset just to get hint if your problem is in the sound output ic. Listen carefully to your headset if there is a sound or none. If you hear a sound then you the trouble is in between the earphone jack or to your speaker. Just test the speaker and you will isolate the problem. How to test the speaker if good, simple got a battery (either AAA,AA,C,D size) then tap the speaker across the battery when you hear a crackling sound then it is good. If you confirm that the speaker is good then the faulty parts is your earphone jack, replacing it will cure the problem. If you don't hear a sound then through your earphone then the trouble is in the output I.C. or some parts around it and you need a technician to isolate the problem.
If you don't have an earphone jack then I've advice you to look for a qualified technician to look for a defective parts on the sound section.
Thanks for using fixya...
Jan 07, 2011 | Televison & Video
I can't hear a sound from my computer,but i can only hear the sound if i connect to a earphone
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control
panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 03, 2010 | Sony Computers & Internet
No sound on speakers but earphones are working in hp G60 243 DX notebook PC laptop may send help at dhingra.ashok@gmail.com
YOu need to replace the speaker for your system since you can hear sound using headphones it means that the sound card is good,
Jul 17, 2010 | HP Computers & Internet
Theres no sound without earphones
or you could try buying speakers for a much ideal sound
Feb 15, 2010 | Packard Bell (030069) Sound Card
Cannot detect when a jack is plugged in.
check your sound card ,,do u have sound threw the pc speakers.if so bad head phones.or not compatable with your pc.
Oct 09, 2009 | Dell A215 Computer Speakers
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop Logo
Alun Cox
