Identical problem. Camera kind of goes into a crash when started...
When I remove batteries and reinsert them, it's ok again.
No change if batteries are fully charged or not - no new firmware available.
Just entered camera in repaircenter - haven't got it back.Identical problem. Camera kind of goes into a crash when started...
You can't post conmments that contain an email address.
No. The power converter inside the camera is damaged some how. It says the battery needs charging because power cannot get to the main circuit - it needs to be taken apart and isolate the crack or open contacts.
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
The problem when a phone gets wet doesnt start after drying. It starts day/weeks later when the phone starts to corrode. If you take it apart check the main board and see if it has any white residue on it.
You can try to clean this off with alcohol but chances are it's going to be a no go.
This normally means that the images will be blurred. Have you turned off the flash? If so, turn it on. If you don't want to use the flash, use a tripod or a higher ISO to prevent images appearing blurred.
CAMERA ON P , FLASH ON TTL , AND LENSE ON F22
WAIT FOR THE RED LIGHT ON FLASH , GOOD MEMORY CARD AND IT SHOULD WORK .
BERRIE SMITH CAMERA REPAIR [email protected]
In your display, is the small lightning symbol appear on the screen? Try cycling through the various flash options by pressing the "flash" lightning symbol to the right of the monitor. If the flash is set to flash when there's not enough light at the G9's descretion (with an "A" next to the symbol) then the flash may or may not go off. I oftentimes set the flash to go off all the time if the camera is not doing it automatically (with the A next to the symbol). Being in Auto mode versus the other preset exposure modes affect the flash options available too.
the red symbol is the erasure prevention slider on the tape. check it's not on or push the slider on and off prevention. this should fix the red symbol, you might have to do it a couple of times before it works. not sure what F14 is can't find it in the manual. try the solution here. if it still turns off after a few seconds i have another way to fix the power.
