My toshiba 28Z23B CRT colour TV is not working properly. It is not staying on once the power button is pressed. Can this easily be fixed?
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
  • 5 Answers
SOURCE: Dish Network 34" CRT HDTV, hold in power button to turn-on
Have you tried using the remote?
Posted on Feb 13, 2009
Techwood tv 42" model 42832 was working nipped to shops so pressed power button on side came back ten mins later switched it on and came on and changes diff colours as seen in video how can I fix this
you have a power supply partial failure if you know how to safely check your power supply check the voltages, swolen capacitors etc. leaking capicators are usually the problem. if you know nothing about power supplies do not look at the tv without the tv unplugged! better yet; have the supply repaired by a professional. a power supply can kill you!
Feb 05, 2013 | Televison & Video
How do i put a code on my urc 11-1625 remote for the Toshiba T.V and could i also get the code for the Toshiba television ?
Set up codes for Toshiba TV are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 26, 2012 | Toshiba Televison & Video
I would like to close the 'black footprint menu' who stay on the Toshiba CX32H60TV screen all the time
Hello
You are talking about the Closed Caption function On problem I assumes. If the remote control to your tV has a "CC" button on it, press it once to eliminate it.
Mar 10, 2012 | Televison & Video
I need Toshiba 36AF61 universal remote codes
Hello
Four Digit universal remote code for Toshiba are:-
Three Digit Universal remote code for Toshiba are:-
013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 20, 2010 | Toshiba 35A44 35" TV
My hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.
<div style="FONT-SIZE: 14px; PADDING-TOP: 10px" itxtvisited="1"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadBox1_lblProblem" itxtvisited="1">my hp 7540 crt monitor menu displays automatically blinks frequently. please hele me resolve this problem. it stays fixed on the screen, unable to do any work.</span> </div><!-- answer --><!-- from fixya rte -->
May 12, 2010 | HP S7540 17" CRT Monitor
Please help me match my Philips Universal Remote controller with Toshiba TV
Okay this goes for the 3000 series remotes it might work for more. Press and hold the setup button until the red indicator light stays on'. Then release the setup button. Press and release the desired mode button (TV,VCR,etc) In your case it would be TV.The red indicator light then stays on.Then enter the four digit code. For a valid entry the red light goes off for a invalid code the red light flashes.With your device powered on push the channel up button if it works you are done. If some buttons don't work try some other codes.The codes are 0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0618, 0627, 0437, 0041, 0313, 0715, 0094, 0802, and 0111. And this helps you give me a vote please.
Mar 04, 2010 | Televison & Video
Rca universal remote (rcr3273) no manual- need
I don't know the exact codes but here is the search method. Make sure the device is on. Hold down the tv (or whichever device your trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly letting it flash until the tv turns off. Then press the stop button...and it is programmed. Thanks
Nov 01, 2009 | Televison & Video
JVC AV27WF36 TV
I have the same problem
Jul 18, 2008 | JVC AV27WF36 TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
