Question about Toshiba e-Studio 161 Copier Copier
Copy quality I got a problom with toshiba e studio-161, i replaced drum , dev, blade etc, still the upper part of copy, about 2 inch wide, comes very light.Cleaned optics, corona wires etc. plz help. thanks in advance. Paul
  • saji_ab Jul 08, 2008
    Thanks for the help. i fixed the problom by cleaning the mirror in the laser unit.thanks
Try cleaning the laser.
Posted on Jul 08, 2008
"Toshiba e-studio 166" raining day,cold
this is the problem of humidity.try not to keep paper in the drawer overnight.place a bulb ina box and then put papers in it to get heated.try always to use fresh **** of paper
Aug 02, 2011 | Toshiba e-Studio 161 Copier Copier
Copy is very light. Cannot open the MENU & hence cannot adjust the darkness of the Copy.
First off all to go to menu Press star (Additional function) - 28 together and again star Go to Function - Density and increase/ decrease the number. DE - DC- 24 Dev - 15 Off - 128 Den - 7-9 And again There may be a number of reasons for a light copy 1. Drum - change the drum if it is run above 10 - 20000 copies 2. Blade - changing the blade simultaneously to improve the copy quality
Thanking you.
Jul 02, 2011 | Canon imageRUNNER 400S Copier
Can a scratch be removed on the drum that gives a black line on the print. While cleaning the machine something touch the drum and created a line. TOSHIBA STUDIO 160
Hello
Unfortunately the scratch on the drum cannot be removed, as the drum is a organic material.
The drum and drum cleaning blade will have to be replaced.
Regards
May 09, 2011 | Toshiba e-Studio 161 Copier Copier
How can i serive estudio161
Hi how are you this is jack ... (jack_pak@hotmail.com)
Dear your copier e-studio 161
you open the upper glass(open the upper glass side cover open the all screw this cover).and clean the scanner lamp and scanner reflacters... when you clean it your copier copy quality much batter.. (BUT VERY CARE FULLY DONT DAMAGE EVERY THING)
PLEASE VOTE ME ..
Thanks .
Best Regards,
Jun 04, 2010 | Toshiba e-Studio 161 Copier Copier
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
Black copies copier toshiba studio 35
Hello sir; It seem like you need periodical service, which is need to replace drum , cleaning blade, and developer etc.
Apr 29, 2009 | Toshiba Office Equipment & Supplies
Toshiba e-studio 55 has 2'' wide black line on all copies
make sure the glass thats an inch wide under the doc feeder next to the large glass is clean if it is then you will probrably need drum or fusing rebuild
Mar 20, 2009 | Toshiba Office Equipment & Supplies
Toshiba e studio 161
already paper jam in feeding assembly so please check any paper jam.or lubricate all drive gears
Jul 08, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio161 Developer
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] “000””000” will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Apr 11, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-Studio 161 Copier Copier Logo
154 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
