Belt keeps coming off my candy ce104 - Washing Machines
  • louised922 Jul 02, 2008
    Thanks DickyIV1, it appears to be a new belt and very hard to get back on but you can see when you manually turn the drum that it's just working it's way off. It appears that the drum and the thing it also attaches to aren't in line anymore ?
    would this mean new bearings ?
    appreciate your thoughts !
    Sergeant:
  • 225 Answers
If the belt is old it might have stretched or be wearing out. The cheapest solution would be to try a new one first before anything else.
If the drum bearings are worn then it might be wobbling around and that could be throwing it off.
Hope this helps. If so,I'd appreciate a rating for my solution. If it doesn't, feel free to add a comment with extra info and I'll try to think of something else.
Thanks, D
Posted on Jul 02, 2008
  • Richard Raynor Jul 02, 2008
    Hi.
    If the two wheels that the belt turns on are not aligned any more, yes it's bound to fall off ! So we need to figure out which has moved. But first of all, does the belt have grooves in it on the inside? If so, the pulley on the motor will also have grooves, probably more than on the belt, so you can choose the "best" set of grooves to line up with the big wheel on the drum.
    Failing that, with the belt off, you could check by hand to find out if the rotating drum will move forwards and backwards inside the fixed drum, by which I mean will the inner drum move towards and away from the loading door? If so, then the drum bearing must be suspect.
    Also check the pulley on the drive motor to find out if that will slide along its shaft. It's got to be one or the other.
    I'm assuming that the machine used to work OK and only developed this fault recently.
    Let me know what you find. Thanks, D
Hi, got a new belt for my candy CM1 166/1 washing machine but it keeps coming off , its the correct belt , the pulley wheel does not have any play and hardly any on motor wheel either ,belt keeps going...
If the belt is coming off the pullies my be out of line .you need to put a straight edge across the two pullies to make sure they are level . And check there's enough tension on the belt .
Nov 07, 2014 | Washing Machines
Cheats and cheat codes
Candy Crush Saga Level 213 help, tips and tricks In Candy Crush Saga level 213 we need to clear all of the Jelly blocks and score at least 130,000 points within 40 moves to defeat this level.
How to Beat Candy Crush Saga Level 213 (cheats ?) In level 213 we can see that we have double jellies everywhere, so we will need to do some serious clearing of candies in the board.
If we can make the wrapped candy + wrapped candy combo just outside the meringues perimeter, this will help us out a lot, but there's still a lot to be done to clear this game.
Once the chocolate fountains come into play we will face even more distractions and make the game even more difficult.
We should keep track of which jellies has been cleared so we don't need to worry about those candy squares afterwards if the chocolates covers it up.
There will be 70 pieces of jellies we need to get, so we should make the best candy combos that can crush through the meringues and get to the jellies underneath.
The bottom pieces are of course the hardest ones to clear here, so any vertical candies we make will be extra helpful in passing through here.
Stars
1 star: 130,000 points
2 stars: 250,000 points
3 stars: 300,000 points
Candy Crush Saga Level 213 Help Tips Tricks and Cheats
Feb 25, 2014 | Microsoft Video Game Consoles & Games
Candy eclypsa ce104
it will need replacing the valve is at the top right on the rear
Jan 12, 2014 | Candy Washing Machines
Have a Candy Tumble dryer which is about 15 years old (model C57). Worked perfectly for all these years but now pilot light goes on and drum does not turn. What could it be?
Hi usually you will need to take the back/front of and you will find a broken belt replace if broken if it's come off put back on. Regards billy
Feb 24, 2011 | Candy Dryers
Drum paddles have come off
Sorry but the only answer to this is a new drum, possibly from the metal pile at the dump, or ask your local appliance guy if he keeps a parts pile out back, many do! Lastly is the terrible "New" drum. They are very easy to exchange. Take the front panel off the machine after unplugging it of course, and remove the two wire connectors from the door switch. It doesn't matter how you put them back on, it's just a loop switch.With the machine lying on it's back take a good look at the belt routing in particular at the bottom right hand corner and remember how it is wound around the drive wheel and the tensioner. then just remove the belt and slide the drum straight up and out.Also keep in mind which side of the belt goes against the drum(one side is ribbed). Take a few pix if you need, that always helped me. Thanks, Dana
Sep 06, 2009 | Washing Machines
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
CANDY TUMBLE BRYER BELT
i changed the belt on my candy civ 100 but it wont turn on yet all the wires seem to be connected and the fuse in the plug is ok
Apr 25, 2009 | Candy Dryers
Dryer not tumbling
A broken belt is very common. If you hear the motor running, that's probably it. The dryer must be taken all apart to replace the belt. Hopefully instructions will come with the new belt. Routing the belt over the motor shaft and around the tensioner is always a challenge.
Apr 22, 2009 | Candy CDV262 Dryer
Candy cdc 266
your belt is probably broken, or your motor is bad, the motor and belt not only turn the drum, but also the fan that moves air out of your dryer so if it cannot move, the dryer gets hot and it thinks this is because the lint trap is full
Oct 27, 2008 | Candy CDC266 Dryer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
