Question about Cameras
Sony cybershot 3.2 mega pixels
My problem is that whenever i insert my memory stick...the screen shows "memory stick error"
i have inserted it correctly n it is clean too...please can u help me?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Try to putin under memory card, even in a store without buying- just to check if the problem is the card or the camera
is it a SD card?
Posted on Jul 02, 2008
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
Please insert a disk into drive E: my pen drive
hey plz help me out of my pendrive...
1)whenever i insert pendrive the error cums please insert disk it gets detect but it shows this error and i cant open
2)second problem m facing dat my pendrive is not showing me in disk management just ican change a drive letter
3)i did everything by changing drive letter also...
plzz sumone can help me out...
Aug 21, 2010 | Generic Memory USB 2.0 128MB Black Pen...
Reinsert memory stick --- I have removed battery and memory stick with no result. Help
Sony says:
Article ID : 101488 (modified 10/29/2009 03:18:00) Question: A warning message appears on the LCD screen when a Memory Stick is inserted into the camera. Answer: The following could be possible causes for the error message to appear:
  1. Verify that the Memory Stick is inserted correctly.
  2. The inserted Memory Stick cannot be used in the camera. Refer to the related link below for compatible Memory Stick.
  3. The Memory Stick is damaged.
  4. The terminal section of the Memory Stick is dirty.
http://www.sony.com.ph/support/faq/101488/product/dsc-w190/modelfirst
Jan 02, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
Storage card formated but it still does not show up. please help
xda orbit can only hold 2gb sd memory stick and doesnt recognise the HD-micro-sd.
or..
try formating it in a PC or laptop.
Dec 11, 2009 | O2 Xda Orbit Smartphone
Memory stick error when camera is turned on
Hi
How about download the user manual from this link
http://www.docs.sony.com/release/DSCV1.pdf
and then, please read page 106 and follow the sugestions they have relative to your memory error.
Are you using the correct memory type recommended for your camera?
Did you insert the memory stick in correctely?
Is the metal part of the memory stick and the camera clean?
Did you accidently recorded video for a long time on the memory stick. The memory stick may be full.
Did you unlock the memory stick if it has one?
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 27, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
INSERT ANY NEW MEMORY STICK SHOWING FORMAT ERROR
Please format memory stick by camera Menu >> Format option.
If problem still exist, try another memory stick and check camera again.
Apr 25, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Sony
there might be a problem with the file system you are using with with memory stick..insert it into card reader > format it with fat 32 file system..and insert it again to solve your problem.....if problem still persist .insert your memory card into mobile and goto your memory card > now select option > there you will see format memory card > so it will format your memory card with correct file system that your mobile wants.....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cameras Logo
205 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
