Is there an easy way to replace the thermostat on a 95 pontiac grand am 2.3 dohc quad 4 without taking out the motor from the car.
    Genius:
  • 1,036 Answers
Hi there.
Yes, You do not have to take the engine out for this operation.
First, make sure that it is the coolant thermostat that is faulty.
When starting the vehicle from cold with a faulty thermostat, the radiator will start to warm almost instantly. The temperature gauge will stay low for a long time, and getting cabin heat within 2 minutes will be impossible.
Thermostats are nearly always located on the engine at the hose outlet to the top of the radiator. As it is at the top front of the engine, access is usually straightforward once any soundcovers etc are removed.
Other related problems are - Electric fan problems (caused by faulty temperature switch) and temperature sensor reradings - caused by faulty sensor, or electrical supply.
Thanks for using Fixya! If this provides a solution, please rate as such. Thanks.
Posted on Jul 02, 2008
99 pontiac grand am se series 3400 liter motor i need to replace the water pump do you have to take the timing chain cover off to it looks like its all connected together
go to the library and get a book for your car with the motor you have in it.this should be a (sohc)single overhead cam motor and not the (dohc)dual overhead cam motor.the sohc motor the pump is located at the rad side of the motor and doesn`t need to have the timing cover removed.if it happens to be the dohc motor then your best to have a shop do the job as its not an easy job to do
this should be a (sohc)single overhead cam motor.this pump is located at the front of the motor towards the rad.thus you don`t remove the timing cover and easy to replace,once you remove the serpintine belt then the pulley on the pump then there are about 6 bolts that you remove to change the pump.if its the (dohc)motor i strongly suggest you have a shop do the job as its not an easy job to do and if you don`t get the timing belts timed exactly you will be sending the heads to the machine shop to repair.
Oct 31, 2011 | 2001 Pontiac Grand Am SE
Cant find any markings on timing chain for a 1996 grand am se
Below are the pictures of the 2.4 DOHC and the V6.
Jan 23, 2011 | 2001 Pontiac Grand Am SE
How do you replace a thermostat on a 1994 pontiac grand am 4 cyl
i own a 1989 ford laser gl and it over heated and bubbling.There is no water in the oil already checked . Could it be the thermostat or a gasket.
Oct 11, 2010 | 1994 Pontiac Grand Am
Where are the spark plug wires located on a 1995 grand am quad 4? Also, how do you access the plugs?
The Quad 4 does not have plug wires. The engine cover plate has 4 bolts. remove them and lift straight up on the cover. the sparkplug boots will come up with the cover plate. They are protruding strait down from the coils(4) and the plugs are down in the valley between the cam towers if you have the DOHC or behind the cam tower if you have the SOHC.
Mar 23, 2010 | 1995 Pontiac Grand Am
Where is the thermostat in a 1995 Pontiac Grand Am?
If it is a quad 4 engine,it is under the water pump,area where the bottom hose connects.
Jan 22, 2010 | 1995 Pontiac Grand Am
Need to replace motor and transmission in a 97 Pontiac Grand AM G
Changing from a 1992 to a 1997 < WILL NOT Be EASY , As you must HAVE the ENTIRE ENGINE WIRING HARNESS , And ALSO the ECM for the older Set up. In the "5" YEARS there Were MANY CHANGES to the ENGINE Components= SENSORS and ACTUATERS .
its just a BETTER IDEA to Stay Whitin a year or 2 when Swaping ENGINES. SIZE OF SENSORS ETC. MAKES IT DIFICULT
Sep 11, 2009 | 1997 Pontiac Sunfire
Diagram of 3.4 DOHC Motor online
Both knock sensors are screwed into the side of the cylinder head between the front 2 cylinders.
Jun 22, 2009 | 1996 Pontiac Grand Prix
95 pontiac sunfire 2.3 l Dohc Quad 4
check and see if your if you timing belt is ok. see if you distorter is turningn round
May 05, 2009 | 1993 Pontiac Grand Am
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
