Question about Compaq Computers & Internet
Laptop computer will not switch on battery ok main lead ok
  • 92 Answers
Motherboard Possibly Blown Up. What Did You Do Before You Last Shutdown The Laptop.
Posted on Jul 02, 2008
Power button does not stay on
Power buttons are momentary switches. They usually just create a temporary ‘short’ to tell your computer to start. Odds are either the switch is broken or, if you’re using a laptop, the battery may not be working. Again, if it’s a laptop, try leaving the power cord plugged in. If the switch starts working the it’s your battery.
If you are using a desktop you can follow the lead wire from the power switch to the main board. There should be a pair of pins it attaches to. By shorting the pins with a paperclip and seeing if the power stays on you can see if it’s a broken switch.
Jan 29, 2018 | Power Computers & Internet
HP dv6000 laptop not charging problem, adapter, battery and power jack looks like it works fine
If your battery, charger, and DC Jack are ok, then the most common problem is the surface mount transistors on your HP's main board called MOSFET's. They are small 30V N channel 8 pin components soldered to the main board. The boards also have transistor circuits which switch back and forth between a charging and discharging state. However these rarely ever fail. The MOSFETS fail because of the thermal loads which they must endure. Although some notebooks (like the Gateway I'm currently on) have a DC jack which serves dual purpose of supplying DC 19V AND connecting/disconnecting charging circuit. However your HP dv6K does not.
However it's worth mentioning that these models have had all sorts of problems...most notably poor thermal design to begin with that usually creates solder connection problems with the main chipset especially on AMD models. Good luck.. :)
Mar 27, 2013 | HP Pavilion DV6500T Notebook
Laptop turns off after mains removed
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets some motherboards cmos batteries are soldered in might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Jan 28, 2013 | Computers & Internet
I have a ibm t43 thinkpad and want to know how to switch between battery and mains use. Thank You
To switch from battery to mains - plug in mains lead.
To switch from mains to battery - unplug mains lead.
Nov 03, 2010 | Computers & Internet
Acer 5920 works only on battery power not mains
hi there
i read your report. OK 1. check plug in connection on the computer to c if its lose. If it's not lose simply try a new power cord. thank you for writing to fix ya.
Best Regards Richard
Nov 30, 2009 | Washing Machines
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
Compaq armada E500
pls checked them with ext monitor your tft may be faulty as your problem reporting
Aug 05, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
13 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
