Question about Zebra Z4M Printer
ZEBRA Z4M PRINT QUE ERROR
A print request for say 50 labels sent to the Zebra Z4M running from Easylabel 5, prints about 20 labels normally then the lcd display flashes printing 165876 of 178989 - these numbers change randomly and the printer just freezes. Any help gratefully recived
Thanks
    Scholar:
  • 185 Answers
I would say the printers buffer has overflowed, try looking around for a Print Buffer to hook up to the printer. The standard Flash is getting very hard to find.
Posted on Oct 29, 2009
  • 31 Answers
This sounds like a power related problem. It could be the power supply (internal) or interference from something outside. I have seen a lot of things cause this but you will need to be the judge of this one. Look around the area of the printer and decide.
Posted on May 27, 2009
  • 155 Answers
Try a reset: press the PAUSE and FEED keys while turning the printer, release the keys when feed the label. You can also try downloading the latest firmware.
Posted on Mar 10, 2009
I turn on the zebra z4m and it runs the labels even with no information sent to the printer. I can not use the cancel or pause button to stop. I runs for a minute and then error condition ribbon out. I...
1.Double check that the ribbon and the labels are routed correctly. 2.Make sure the media guide is holding the labels against the inside of the printer and not moving to the right away from the media sensor. If the labels are sliding to the right as they come out, increase the left side head pressure on top with a flat blade screw driver. Download the user manual at zebra.com .Check the media type and sensor type, and set for thermal transfer if using a ribbon.
Feb 24, 2011 | Zebra Z4M Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Running two Zebra's through Easylabel Platinum
When connecting Easylabel to a Zebra through the RS232 port, it's very important that the serial settings match between Easylabel and the printer. Easylabel defaults to 9600 baud, 8 data bits, none parity. The Zebra defaults to 9600 baud, 7 data bits, and even parity. This mismatch causes the data light to flash but no print.
Change the printer setting to 8 data bits and none for parity and the baud rate can be whatever but make sure they match from Easylabel to the printer.
Hope that helps !
Sep 18, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Delay in printing labels with Zebra Z4M
Set in the driver the size of the label and print mode to Tear off.
Roberto Martinez
Jul 22, 2009 | Zebra Z4M Printer
Zebra M4 is printing blank labels
Did you switch your ribbon as well?
Jul 06, 2009 | Zebra Z4M Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Can't print images on zebra z4m printer
Check the "Dithering" setting in the printer driver. Turning "Dithering" on improves graphics but reduces speed of processing.
Apr 07, 2009 | Zebra Z4M Printer
Z4m zebra printer problem
Might foul the ribbon sensor, clean the sensor and try to print again.
Mar 02, 2009 | Zebra Z6M Plus Thermal Label Printer
Label Printing stuck in queues
I think your problem comes from your spool server. Check if you can select not to reprint on errors. As far as the error issue is concerned, i need to konw the reason of the errors to help
Jul 21, 2008 | Zebra Z4M Printer
Zebra Z4M won't print whole label
Did u try system restore?It will restore all of ur settings to how they were when it was working...
Oct 08, 2007 | Zebra Z4M Printer
Zebra Z4M Printer Logo
454 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
