Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Sound Card "This Device Cannot Start"
In device manager it says my sound card cannot start, which make sense since i can't hear anything from my speakers. the troubleshooting instructions say to uninstall the device and then use the add hardware utility to reinstall then update the drivers. However as soon as i try the Add Hardware step i get a BSOD. the first time this happened it also corrupted my video drivers and i had to uninstall and re-install them. Second time it happened (decided to try the process again) i didn't bother checking if the video was screwed i just re-installed the drivers. In short where do i go from here? I have a Dell Dimension 8400 P4 3.4 GHz, Nvidia 6800 gt thats been running hot (72-78 celsius) partly becuase of the room temp, and as for the sound card its a Soundblaster Live! 24-bit. I have already downloaded the most recent drivers from Creative labs website as well as the application suite that is needed after re-installing drivers. but they are of little use to me if i can't properly uninstall and re-install the device.
  • 1 more comment
  • Temper11 Jul 03, 2008
    I've disabled my onboard sound, i somehow managed after many tries to get it working just by disabling both the soundblaster and the onboard then re-enabling the soundblaster and using the windows wizard to install the drivers, the driver installation didn't even complete properly but my sound actually works, its causing lord of the rings online to crash but thats probably becuase of the state of the drivers. i will try your solution to see if i can get a more complete fix. any idea why trying to install the web release drivers results in my video drivers being corrupted and sound card having the code 10 error again??
    i took the card out and put it into a different slot, upon restarting windows detected the device and from there sound is working so far, at this point i'm curious if i should now try to install the web release drivers, i'm sure i have the right ones i was very careful about that, everytime i've tried them before it caused problems but maybe now that its been properly re-installed they will be more use.
  • Temper11 Aug 04, 2008
    Ok so all previous issues have been fixed except one. i don't think i posted about this but when i play Lord of the Rings Online or the Kung Fu Panda demo with the sound card enabled the next time i restart or shut down my computer after playing, i will have to reinstall my graphics drivers.
    The reason is that as soon as the system reaches the desktop after booting up the screen goes black, all system lights indicate normal operation of the computer (i have a dell dimension 8400). shutting down booting into safemode and uninstalling the graphics card and then when it restarts the most reliable way to get job done is to go back into safe mode and re-install the drivers (have them on file) from safe mode. at that point everything is fine until i play either of those games with the soundcard enabled. Other games such as the COD4 demo or the Lost Planet demo do no cause this issue.
I have no sound
Posted on Oct 01, 2008
    Genius:
  • 1,019 Answers
the soundblaster cards, usually have to set an interupt port IRQ.
This can sometimes conflict, with any other device connected i.e printer/paralel port.
I,d suggest, power off the computer. and remove the mains power cable. then completely remove the soundcard.
either try the card, in a different pci slot, if you have a spare.
or reboot the computer, without the card in at all.
shut-down, power off. re-insert the card and re-install.
also check, the on-board sound card is working correctly if applicable. you may have a conflict between the on-board and standalone ( soundblaster Card ) attempting to share the same driver or resources.
Finally check the motherboards jumper settings ( User Manual ) to enable/disable the onboard sound. if necessary.
And check the settings in BIOS.
Mike @ compurepair.
Posted on Jul 02, 2008
  • Mike Waldron Jul 03, 2008
    Thankyou for your Rating.
    This could be relating, to the Overheating CPU. It would be practical, to remove the CPU Heatsink/Fan. And clean re-seal with a good thermal cement ( Arctic-Silver Or Similar )
    The only real way, to setup these cards is from a new install.
    I still think, the problem is relating to another device Sharing the Same IRQ. Sounblaster cards are reknown for the sharing issues. Other suggestions are to re-install the card in a seperate PCI Slot. And to backup your data, and re-install the system with the blaster on-board at initial settup.
    Regards Mike @ Compurepair.
    I,d have to say " if it isn,t broken - Don,t fix it "
    Theres so many different blaster-sound cards. if you ensure you get the correct drivers, for the card. it should be Fine.
    Better still, if you can try and get a setup disk. there may also be other various applications. for use with your card. such as a mixer-sound recorder et,c. Good luck and many thanks for your Rating.
    Mike @ Compurepair.
Cannot hear anything,..
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 19, 2011 | Tascam US-122 Sound Card
No sound available
You should first check if sound has been disabled, and if not, whether a sound card has been installed. On your taskbar, ---the horizontal strip conraining the start menu---,which is usually at the bottom of your screen---on the right hsand side--open thr volume control to check if it has been muted. If not go to DEVICE MANAGER on control panel to see if a sound card is among the devices installed on your computer. In Vista device manager is in Control Panel>Administrative tools>Computer Management>Device Manager. Use Help on your start menu to locate device manager. You should heard sound if sound is not muted and a working sound card is fitted
Dec 27, 2010 | Computers & Internet
From my onboard sound ac'97 did not hear any sound. when i try to sense form sm frunt , sarround, mic in connector fail apeared.
visit you device manager and make sure all drivers for your sound card are installed
1. right click my computer
2. click properties
3. click hardware tab
4. click device manager
if under sounds (audio) category you will see yellow question marks, then please install the required drivers
Aug 10, 2009 | Computers & Internet
Hi i'm just new at this. we have no sound what so ever. i found the sound chip number or something. how can i get my sound back online again?
1. Lets start with the obvious. Make sure the volume mixer control is not muted. This is usually a speaker icon at the bottom of the screen. If you do not see this then go to control panel, sounds and audio devices, and make sure nothing is muted.
2. check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 09, 2009 | Apple Griffin iMic External Sound System
Have cd13v75201004 sound card but canot cat sound from my computer orion computer
I would update the sound card driver anyway just in case. Drivers can get corrupt. Just happens.
Hope this works.
Brian
Jul 07, 2009 | Apple Computers & Internet
Soundcard seagate ST320014A
Sound Not Working (discrete sound card)
You probably need to make sure the new sound card is properly installed. Check device manager and make sure the new sound card does not have a yellow exclamation mark next to it.
If the card and driver are propery installed, then you can either disable the onboard audio from BIOS (enter this when the computer first boots up by pressing either F2 or delete several times)
Or
go to control panel, sound, and check the sound card as the default. Do this for .WAV and .MIDI and whatever else you see.
And that should take care of it.
No Sound (integrated Sound card)
Jul 07, 2009 | Intel Computers & Internet
Cannot instoll my motherbord sound card drivers
Check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
Jul 06, 2009 | E-Mu 0404 Sound Card
I cant here any audio sound on my computer
There are a few simple things to check first:
• Make sure your computer has a sound card.
You must be logged on as an administrator to perform these steps.
1. Open Device Manager by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ getopencontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=xml If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
NoteIf you think you have a sound card installed but you don’t see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there. 3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
May 06, 2009 | Computers & Internet
Error code 1B63:161B
have you changed anything in your system
open device manager then click on your audio driver and do an update
when did this prob start
Jan 26, 2009 | Dell (8H390) Sound Card
My sound card
if you click on start, my control panel, printers and hardware, then down the left it will say system click on that then go to the device manager in device manager right click it and then update driver, that should work
Jan 24, 2008 | Medion M3 Composer 5200 PC Desktop
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
285 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
