Question about LG WM-1290FHB Front Load Washer
Lg intello washing machine fills but will not wash or spin
  • ocka Jul 03, 2008
    Thanks but this motor does not have a belt. there is no smell of burning, and the drum turns free. The motor seems to be made up of several single coils.. Thanks again for your help
  • Ashajack Jul 04, 2008
    I have an LG intellowasher 7kg wd-8013F. It fills with water though will not spin. The belt is intact and the drum will turn freely by hand. I am guessing that the brushes may need replacing? As I do not have a manual, any other theories would be greatly appreciated.
    Thanks
    Sergeant:
  • 225 Answers
Any strange blue lights underneath, or noises or smells? I'm thinking it could be the motor brushes but it could also be that the belt has fallen off.Can you hear a whirring noise like a motor turning? Does the drum turn OK by hand when you open the door?
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please add a comment with any extra info you have and I will try to think of comething else.
Thanks, D
Posted on Jul 02, 2008
Water turned off unexpectedly now machine won't spin final cycle and timer stays on 4 min and appears to continually try and drain ( intello 7.5
Unplug unit for 5 minutes to reset control board. If problem still persists, you will need to call a technician to service it.
Jun 15, 2011 | LG WM-2277HW Front Load Washer
I have a 2 year old l.g.intello apartment size washer numberwft8501tp it is touch control and i have no idea how to start it please help
I suggest you go on-line and type into your search engine 'lg intello washing machine manual'. You should be presented with a number of sources from which you can either download for free or have to pay. At some point they will ask for your particular model- wft8501TP- obviously!
Good luck,
John C
Feb 10, 2011 | LG Washing Machines
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
Lg intello WD1243FH low water level? My Lg will not fill with water properly. It only lets in enough water to get the clothes wet then stops filling. I tried filling it manually through the drawer but as...
Try adjusting the water lvl going into the washer. Adjust accordingly. If you have a meter, just the resistance of the valves. Unplug of course. It should read about 1.4k ohms ish. Could be higher or lower but roughly that.
Apr 28, 2010 | LG Washing Machines
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Apr 01, 2008 | Washing Machines
LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Jan 06, 2008 | LG WD-16115FD Front Load Washer
LG WM-1290FHB Front Load Washer Logo
151 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
