Hey how can i solve my PLASMA TV JVC D.I.S.T,SUPER DIGIPURE BBE,INTERIART.which THE SCREEN IS FINE,BUT WHEN PLUGGING IT INTO A ARIAL I CAN NOT GET A PICTURE,JUST SOUND.
5 Suggested Answers
SOURCE: plasma television
covergence
Posted on Apr 08, 2007
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
  • 4234 Answers
SOURCE: JVC Interiart 32" Digital TV.
The thin line indicates that there is no vertical. This is usually controlled by a single IC (vertical IC). Look for a small flat IC attached to a heat sink with 9-14 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC with a new one.
Keep us posted.
Dan
Posted on May 09, 2008
  • 47 Answers
SOURCE: my jvc plasma tv seems
Your tv has failed. You need to count the blinks, they are a code.
you will need expert help for this
www.classtorations.com
Posted on Jun 09, 2008
Why my 55in plasma some times wont get signal. arial ok other tv good on same arial lead. doesen't happen all the time ?
How old is your cable? How old is your outside anteena? After awhile they need to be replaced or connections checked. In my area the tv has been going out for hours while they work on it. But you seem ti indicate that is not the problem. What type of cable are you using? An which connectors? Need more info
Jan 28, 2015 | Samsung 50 in. Plasma TV
Jvc interiart television
hook up box to a stereo thur av jacks if it dod it thur stereo then its not your tv its your sky
Sep 19, 2013 | Televison & Video
How do you get the "LOUD" screen to come on the
Some of JVC higher end models have a feature called BBE. The BBE button has replaced the loud feature on these models, so there is no Loud button on them. Some of these display panels still might show the Loud indication due to the display boards used.
I suggest check ypour User Guide for additional details. Good luck.
Oct 14, 2011 | JVC KD-SX870 CD Player
Volume out on a jvc bbe d-ila tv, what can i do to fix it?
Cannot get sound on JVC BBE D-ILA, what do I do to fix it?
Aug 20, 2011 | JVC HD-61FH96 61" Rear Projection HDTV
Good Morning\r\n i have a JVC Interiart 29" Flat screen tv which is 8 years old which has started making a noise when switched on,a very loud humming noise and no picture for a couple of minutes then the...
That usually indicates a capacitor going out in the power section or flyback section of the board inside. Depending on your repair shop this can be a fairly cheap repair (or not). Get an estimate and know what a replacement tv is worth. Sometimes its cheaper to get a new one than repair the older tv. As well power problems can stress other parts so it might get fixed only to fail later.
Jun 14, 2010 | Televison & Video
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Total black TV
hey hello, you have a bad buffer board. some tvs have them on the sides and another tvs have top and bottom of the screen.it should not cost more than $150.00 for the board. i think that's too much.a tech will determine easy and fast the one that is bad. that is a fast repair good luck
caypianan@yahoo.com
May 10, 2009 | Sanyo DP42746 42 in. Plasma Television
JVC Interiart 32" Digital TV. No longer turns on. Has a thin horizontal line across screen when TV is on. No picture.
Keep us posted.
Dan
May 09, 2008 | Televison & Video
JVC plasma display receiver - sporadic line problem!
ik heb dit probleem ook sinds gisteren, hoop dat iemand weet hoe dit opgelost kan worden.
Nov 23, 2007 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
