Question about Canon L120 Fax Laser Printer
Canon Fax-L120/L100 We cannot send faxes it says|:- Caution check scan platform
  • 1 more comment
  • jjproperties Jul 31, 2008
    i am trying to send a fax, but it does not go through, it says "check scan platform" what do i do?
  • saadialfa Aug 31, 2008
    My problem is the same, it say me to check platform problem and when i escape this step and i can tape the phone number and press send, I have "PCL DOC" as a message. the manual doesn't specify anything about this.
    can anyone say me what can I do?
  • peepatjai Jan 29, 2009
    i am trying to send a fax, but it does not go through,on the display says "check scan platform" , what can I do???
Check the manual for how to clean the scan platform (glass).
Posted on Jul 08, 2008
What happen my canon fax L100 not sending and resiving
I would look to make sure that the phone line is installed in the LINE port and not the handset....
Jan 11, 2014 | Canon L120 Fax Laser Printer
Canon L120 - What does this error message mean?
Check Scan Platform, means:
The scanning platform is dirty, or not set into scanning position.
Solution
Clean the scanning area, or lift the scanning platform into place.
Nov 26, 2011 | Canon L120 Fax Laser Printer
I have a faxphone l120 every time i try to send a fax is say tx cancelled and goes to check scan platform i need instructions that are dumby proof
Hey! If you take out the cover thats covering the recieving paper,Look in there and u will see a black lever with a green sticker on it!You should see a thin glass covering a whitish area,Push that up untill you hear the clicking sound! Enjoy!
Sep 09, 2010 | Canon L120 Fax Laser Printer
Cant fax, getting a msg "check scan.platform" Thank you, Z
When you remove plastic cover, wich is above paper cass. you will be able to see long black plastic with white scanner section.In the midlle is handle.
You need to open and very vell close it - THIS IS SCANING PLATFORM.
If does not help you have problem with main pcb.
Jun 15, 2010 | Canon L120 Fax Laser Printer
Canon fax L120/L100
Is the device set as printer or you use it just as fax?
If it is set as printer, under printer properties check the paper size, ussually is selected ltr. you need to set it as A4.
Aug 08, 2008 | Canon L120 Fax Laser Printer
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 31, 2008 | Canon L120 Fax Laser Printer
Check scan platform
Two things cause this, a dirty scanner or after the user cleaned the scanner it was reassembled incorrectly Directions are in chapter 8-4 of the “Basic Guide”
Apr 02, 2008 | Canon L120 Fax Laser Printer
Coulnd't send a fax
I had the same problem and called canon helpline.
They said to unplug the machine from the mains, then take out the plastic guard where the paper tray is fitted. There is a lever just above the paper tray. Make sure that it is pressed up completely. Then reconnect to mains.
I tried it and it worked.
Dec 27, 2007 | Canon FAX-L1000 Plain Paper Laser
Can't recieve a fax
i have fax L100 ,i can send a fax but i cant recevie a fax error is communication error (003F)
Oct 24, 2007 | Canon FAX L-120 Plain Paper Laser
Canon Fax L120/L100
press menu and then # goto service mode. Select the clear data function.
Clear all the memory, dRAM and counter.I hope it will work for you.
May 10, 2007 | Canon L120 Fax Laser Printer
Canon L120 Fax Laser Printer Logo
736 people viewed this question
old marine
old marine
