Question about NetGear RangeMax WPN824 Router
My router is acting retarded
Its not letting me ply xbox, and it dosent give out a wireless signal
  • 89 Answers
First of all make sure the router has wireless capability.
if it does then make sure the wireless settings are configured properly, if there is a wireless computer working then that means it is configured fine already.
if the above are already met then you might need to open certain port numbers in the router settings for the game that you try to play in xbox.
Posted on Aug 24, 2008
I cannot conect to xbox live. I have internet and wireless .its tells me to test connection when i want to play on line. so i do that .i test it and its stops at xbox 360 to my internet.so i dont know what...
If its not a black xbox 360 slim than it doesnt have wirless so you either need a wireless adapter or ethernet cord that will hook up to the modem from the xbox.
Sep 17, 2011 | Video Game Consoles & Games
I was having trouble getting a signal on my xbox 360 so i unplugged and plugged my router back in, this caused it to not put out a wireless signal, it does produce internet through an Ethernet cord, but...
It can take up to 2-5 minutes before your router starts broadcasting a wireless signal and for the xbox to be able to connect to it, turn your xbox off and the router wait a minute then turn your wireless router on, wait a further few minutes and turn your xbox on and try using the wireless connection
Jun 27, 2011 | Paradyne Zhone 6218I2 ADSL2+ 4 Port WiFi...
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
My x box 360 keeps freezing ans saying you are disconnected from xbox live, what do i do ?
If your screen freezes when playing on Xbox LIVE, the problem may be related to your Internet connection. A weak wireless signal can cause poor Xbox LIVE performance. If you are using wireless connection:
1. Go to My Xbox and select System Setttings. 2. Select Network Settings. 3. Select Wired Connection or the name of your wireless network. 4. Select Test Xbox LIVE Connection.
If your wireless signal is only one or two bars, try improving your signal strength by following the suggestions below.
  • Move your router or gateway off the floor and away from walls and metal objects such as metal file cabinets).
  • Minimize obstructions along a straight-line path between your Xbox and your wireless router or gateway.
  • Shorten the distance between your console and your wireless router or gateway. Ideally, your network hardware should be near the center of your home.
  • Change the position of the antenna on your Xbox 360 Wireless Networking Adapter (external adapter only).
  • Turn off wireless devices. If your router uses the 2.4 GHz band, try turning off wireless devices, such as 2.4 GHz cordless telephones and Bluetooth devices.
  • Try changing your wireless channel. Wireless routers and gateways can broadcast on different channels and one channel might be clearer than another. See your hardware documentation for help changing wireless channels.
  • Add a wireless repeater to extend your wireless network range. You can boost your signal strength by placing a wireless repeater halfway between your router or gateway and your console.
  • Add an Xbox 360 Wireless N Networking Adapter.
  • Switch wireless signal bands. If you have a dual-band router and an external wireless adapter, try switching the router to a wireless protocol that transmits on the 5 GHz band (wireless protocol A or N). Please see your hardware documentation for help with changing the wireless protocol.
  • Switch to a cable.
Apr 05, 2011 | Video Game Consoles & Games
Light is turning red not green and sometimes dosent come on when xboox is turned on
the adapter only comes on usually when the xbox is turned on and booting itself up. try restarting the xbox over and over again and replugging in the adapter.If the light is red that meanes its on and running but cannot connect to your router or modem etc. if this is happening reconfig your connection so it recognizes your router.IMPORTANT: if you have security on your router you must enter everything in before you can connect. If your adapter still doesnt read your router you must be out of range or the router is not putting out a signal.
Feb 05, 2010 | Microsoft Wireless Network Adapter Xbox...
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
My Xbox 360 wont sync any of my wireless controllers and the powe
if your wireless controllers wont sync to your xbox, it could be one of 2 things.
assuming your batteries are fully charged, and that you're using a certified xbox controller, it could be that the controller itself. it is really rare that the wireless receiver inside the xbox itself, goes out, but soemtimes, it happens.
the easiest thing or you to do would be to either pick up an after market controller, or another certified controller, and see if they'll work. if you try other controllers, and they STILL dont work, verify that your system settings are correct, or are set to default, and make sure that your xbox isnt sitting close to something that could be interfering with the signal....like a wireless router for example
if this doesnt work, then it's a problem with the xbox, and you should send it back to the service repair center.
Sep 24, 2009 | Microsoft Xbox 360 Wireless Controller
Cannot change wireless settings on XBOX 360
xbox only supports wpa or wpa key,
its possible that your wireless security is in wpa 2,
Nov 26, 2008 | NetGear WGR614 Router
Xbox 360 and linksys
ya do one thing in the linksys router give port forwarding it means that your seconed router ip address give to the first router in the option the port forwarding you get the wireless.
or do one thing use the one router and other use access point then you get better then the best .
Jun 18, 2008 | Linksys Wireless-G WRT54GS Router...
Wireless connection problem - XBox Live
Make sure that the wireless settings on your router is the same as the settings on your XBOX also the Xbox should be able to work when wired to the modem to make sure that ports are not blocked. You can give that a consideration too.
Hope this helps, if you have other questions, message me then I'll answer it as soon as I can.
Apr 28, 2008 | Microsoft Wireless Network Adapter Xbox...
NetGear RangeMax WPN824 Router Logo
37 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
