Question about Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 false "Replace Paper Tray" message
Xerox 8200 paser
low capaccity tray
printer normally just sit there priting quite happily
All of a sudden we have an error message "reppalce paper tray" - but the paper tray is there.
Resetting the printer doesn't help
So most likely we have a dead sensor.
Can someone please help me identify where the relevant sensor is, and if there are any typical faults that would cause the problem that I am seeing.
Thanks
I've had a similar problem with a client's 8200 printer, and looking at the right hand side of the tray someone had previously put some tape over the topmost 'slot' (above where the green slider goes across).
I put some new tape over the top slot and the 'replace paper tray' message went away.
Admittedly, the tape gets pushed in so I don't know how long it will be before the tape gets dislodged and the error re-appears.
The printer is well out of warranty and they don't want to pay anything to get it fixed... so this solution is fine with them.
Hope this helps someone else out there :-)
Posted on Jan 28, 2009
Tape over the top slot above the "transparency or paper" green slide with a piece of electrical tape. Ensure that the tape is secure (will not slide around to the touch). Poke small hole in center of tape. Insert a #8-32 x .415" slotted-head machine bolt (binding post) through the tape then install #8-32 nut on inside. This should reinforce the tape as it contacts the side sensors...
Posted on Aug 18, 2010
Tape over the top slot above the "transparency or paper" green slide near the front on the right side worked. In addition, when I pulled the tray fully out, I saw the small plastic tab that was supposed to go there sitting on the bottom of the slot the paper tray was supposed to go in. Perhaps finding and replacing that back in the correct area will be a more permanent fix.
Posted on Jul 08, 2010
On right hand side of tray at front, but these normaly only break during paper load. it is normaly not the sensor but rather the tab it rubs against. you may be able to use the manual feed tray
Posted on Jul 18, 2008
4 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
Posted on May 24, 2009
wrinaldo
  • 185 Answers
SOURCE: Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Posted on Aug 10, 2010
StevenC82
  • 160 Answers
SOURCE: Xerox Phaser 7700 laser printer problem. Display
If your Xerox phaser 7700 7750 or 7760 is having a Paper Jam at A-Fuser error, this video should help. Good luck
Posted on Apr 06, 2011
Message 'Empty trays constantly displayed, although trays were emptied
Xerox Workcentre 7855 Bypass Tray 5 empty - Customer Support Forum
forum.support.xerox.com/t5/Hardware/...Tray...empty/td.../14901...
XeroxSep 29, 2014 - All my 7855 have the Tray 5 (Bypass) is empty. message. .... as there is no paper in it the message will always be displayed in the driver here:. Error message-Paper Tray is empty
Dec 8, 2011
Phaser 3600 reports as paper try empty
Oct 20, 2011
8560 waste tray error
Dec 13, 2010
More results from forum.support.xerox.com
empty drip tray Questions & Answers - Fixya
www.fixya.com > Forum > Tags
But now the display shows "Empty the drip tray" constantly. ... Empty Drip Tray message Getting the message "Empty Drip Tray" even when the tray is completely .
Nov 21, 2015 | Office Equipment & Supplies
My Xerox Phaser 6128MFP printer flashes red light after every print out....
First, when you put the paper in the tray make sure the paper holders on the side and back of the tray are positioned against the paper stack but not so much as to be snug.
Next, inside the compartment where the paper try is inserted look for a small plastic piece that hangs below the ceiling of the compartment. It should be near the front of the compartment hanging down and should swing freely backward.
Also, in the printer's paper tray settings make sure that tray is set to that size of paper you are using.
Apr 02, 2015 | Xerox Phaser 6128MFP AllInOne Laser...
Xerox phaser 8560 printer is saying waste tray missing but it is not
Are you sure you are looking at the waste tray, and not the paper tray? Here is a link to the user manual for the printer. Information about the waste tray is on page 194. This should give you an idea of were it is located.
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf
hope this helps
Feb 22, 2012 | Xerox Phaser 8560/YN Printer
Hi wogan2:
Inspection
Rollers:
 Flat spots
 Out of roundness
 Cracked rubber
Part # 401-0882-00
Hope this helps
May 21, 2009 | Xerox Phaser 8200 Laser Printer
Replace Paper Tray Message won't clear
On the right side of the tray, there are 3 rectangular holes. The "plug" goes in the top hole but, if it came out, it probably won't stay in. I've taped a piece of sheet metal in the hold before to get by. You can buy the part for a few bucks from xerox or inktechnologies. There is a lot of pressure on this plug so it takes something pretty strong to hold.
Mar 12, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Xerox 8200
There are special cleaning sheets that you need to get for this printer. Ask the company you get your ink from, they should be able to get you some.
Sep 23, 2008 | Xerox Phaser 8500N Printer
Phaser 8200
Have you loaded both trays? The bottom tray and the upper tray ? The one that folds into the machine. Something may be trying to run from tray 1. Upper tray
Jul 17, 2008 | Xerox Phaser 8200 Laser Printer
Paper tray stuck
On the Brother DPC130C
Take off the back cover, sort of triangular piece of plastic.
Take power cable out, turn the device on its side and look at the back in the centre there is a white piece of plastic lift that up with a ruler or such device lift the white plastic thingo and slide the tray out.
Don't forget to put all pieces back in place before using printer.
Jul 02, 2008 | Xerox Phaser 8200 Laser Printer
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
Error Msg: Maintenance drawer A is missing - Phaser 8200
There is supposed to be an orange chip on the back of that tray.
If that is not present or seating properly that will cause that problem.
Pull out the green tray and see if the chip is snapped on the back ot the maintenance tray.
Oct 17, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Laser Printer Logo
665 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
