Question about Philips 26PF5320 26 in. LCD Television
Additional speakers How could I connect additional speakers to a 26PF5320. The sound quality is very poor but I have got no manual to check which sockets I could use. Regards
    Scholar:
  • 66 Answers
Two options use the RCA audio out (red and white) on the back or side of the tv to connect to a home theatre system also you could use the headphone jack to connect to a home theatre system or some sort of external speakers. other than that it doesnt look like you have too many options on that model of tv if you need the owners manual here is the link for an online version.
http://dl.owneriq.net/7/767eb69d-bd30-4de2-9391-fbb098cdf71c.pdf
Posted on May 24, 2009
Radio sound low and squeeky, works good in summertime
The volume control on your radio is called a potentiometer, which may be going bad. It works better when its warm because materials expand as they warm up and make tighter contact with each other.
It is also a possible a bad wiring connection exists. Poor contact will cause static, poor audio quality and intermittent output.
Your radio will have plug type connector(s) Your speakers will most likely each have two wires with single female spade connectors of different widths (keeps the polarity correct) the wire with the stripe (of whatever color) will be connected to the negative (-) speaker terminal.
So you need to check all the connections, one is making poor contact.
If both speakers (assuming you have two) sound good or bad... then start with the plug connectors for the radio and any independent black ground wire coming out of the radio.
If one speakers sounds okay check the connections on the other one. You check the connections by carefully pulling the speaker wire off of the speaker and then carefully pushing it back on making sure it feels tight and secure.
PS: If you pull the fuse for the radio, the radio will have no power and will not work. The radio coming on proves the fuse is good.
PSS: Your owners manual should provide lots of information on your sound system components.
Aug 11, 2017 | 2000 Chevrolet Silverado
Motorola H19txt has very poor sound quality
sadly you have poor quality loudspeaker. the only thing u can do is plug in a powered speaker set into the headphone socket.
Nov 20, 2013 | Motorola Mobility H19txt Universal...
Poor sound quality on philips flat screen
check it high quality port behind the pc correct connection in the socket
Sep 27, 2011 | Philips Televison & Video
Sound quality is so poor. cant listen music. volume is too low even with full sound
Normally the sound on the Vostro is lower than the Inspiron series as this is an executive office laptop.
All what can be done is you can download WINAMP and use to increase the equaliser /volume still further.
Also an active power speaker can be connected to the earphone socket to improve the volume to your desired level.
Jul 13, 2011 | Dell Vostro 1014 Laptop Computer
WHATS THE MOST LIKELY CAUSE FOR A PHILIPS MC235B TO HAVE NO SOUND FROM SPEAKERS OR EARPLUG?
... based on a lot of assumptions that all is connected and the desired source is selected correctly...
Have you looked at the manual?
Sound cannot be heard or is of poor - Adjust the volume.
quality. - Disconnect the headphones.
- Check that the speakers are connected correctly.
- Check if the stripped speaker wire is clamped.
What DOES work?
Apr 19, 2011 | Philips MC235 Shelf System
I turned on my home theater sc-ht670, and the display shows "hello", "init ", "please" and finally "wait" and nothing happens and be left with the word...
Basic steps to check if the problem lies with the home theatre system or not.
1. First thought might be to conclude that your poor audio quality is caused by your speakers, before you immediately race out to purchase a new home theater surround sound speaker package, check the basic things first.
2. The problem might not be in the speakers, but in the amplifier or the connections from the amplifier. Checking and ensuring that the speakers are correctly connected on both ends is the first step.
3. After the connections pass examination, the next step is to check if the problem lies with the amplifier or audio speaker. Some of the lower end home theater systems come with low powered amps. Most often they do not supply sufficient power to speakers to produce the quality audio you desire. This may show up particularly if the room is large when the sound doesn't fill up the room.
4. To determine if it is indeed the amplifiers then hook up your speakers to a stereo; this generally will have a more powerful amp. If the speaker quality improves then the problem probably lies in your home theater amplifier.
If you cannot distinguish any difference, then your speakers could possibly be at fault.
5. Poor cable installation and audio speaker cable are another possible cause for consideration. Cheap workmanship can lower audio quality and home theater packages often come equipped with inexpensive poor quality cables.
6. If you experience problems with your theater system, it is always best to assume the problem lies in the connections between components first and then suspect the components themselves.
7. To ensure a great sound experience ensures that everything is properly connected, your amp is of sufficient power, and the cables are of high quality. If a person makes use of these basic easy precautions a significant amount of frustration can be eliminated. If your home theater sound isn't where you need it to be, use those hints as a blueprint as you analyze your system. If it really is time to look for new components, consider those directives as you make your next purchase.
Note : Check to see if the color is bad across all input sources. If so, make sure you have your Televisions' color settings set to your preferences. If everything looks good except, say, your DVD player, and it is connected to your TV via Component Video Connections (which is composed of three cables - Red, Green, and Blue), make sure they are matched up correctly with the Component (Red, Green, and Blue) connections on your TV. This is a common mistake as it is sometimes hard to distinguish the Green and Blue connectors if the lighting in the connection area is dim.
Mar 21, 2011 | Panasonic SC-HT670 System
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Onkyo 6.1, 75 watts connected to sony blue-ray.quality sound not there maybe because I have it connected to reg. stereo speakers with klipsch center speaker.If so, what speakers work good? Iam on a...
How much of this scenario is NEW?
Within limits: Speakers is speakers. They don't know how many other channels are there, so their sound quality is independent of each other. Send them good sound and they will reproduce it.
Improper setup will hurt the 'sound' as much as poor speakers.
Not knowing what you have for speakers now, I would advise you might get yourself somethingto serve as a sub an some surround speakers before you declare your current speakers faulty.
Mar 31, 2010 | Audio Players & Recorders
Poor sound quality with a infinity sound system.
Remember seing something under one of the seats ,but in my old age it could have been a cd autochanger
Nov 10, 2009 | 1990 Plymouth Voyager
Very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Philips 26PF5320 26 in. LCD Television Logo
333 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
