Question about Car Audio & Video
Intstall sub and amp - Car Audio & Video
    Master:
  • 726 Answers
Ok not much info but
u need a red thick wire with a fuse from positive on battery to positive on amp
thick black ground wire from negative on amp to car body
remote wire from remote on amp to remote on back of head unit
rca leads from back of head unit to amp
then hook up sub
Posted on Jul 02, 2008
How can i get my speakers fixed
It may not be the subs, but the amp could have caused the subs blowing/freezing up. If an amp is clipped it will send to much voltage to the subs, thus blowing the subs. Clipping the amp is when someone sets the gains on the amp to higher than the sub can handle. Find this out before you buy new subs. If not, you may have blown subs again.
Sep 28, 2012 | Alphasonik PSW112C Alpha 100 Series 12"...
I have 2 amps instalkled in my car one is sony 1200w 2 channel amp for speakers and one is solid audio f2500d for 3 subs my sound and every thing was good but suddenly from yesterday im having trouble when...
First disconnect the CD head unit from the sub amp and see if the other amp works. If yes, the problem is the wires to the amp, the amp itself, or the subs/sub wiring. If no, the problem is the head unit--probably an internal short.
If the other amp works with the sub amp disconnected, reconnect the sub amp to the head unit, but disconnect the sub wires from the amp. Try the CD player. If the amp goes to protect with no speaker wires attached, the amp is bad. If the amp is OK, the problem is the subs or sub wires. Hook the wires up to the amp again, but disconnect them from the speakers. Try the player again. If the amp goes to protect, the problem is the amp wiring. If not, the problem is the subs. Check the impedance of each sub using an ohmmeter to determine which amp is out of spec.
Please let me know if you have questions, and thanks for using Fixya.
Jun 11, 2011 | Solid Audio F2500D 1-Channel Amplifier Car...
I have a 1100watt sub woofers, and a 1000 watt amp. Will the my sub woofers, or amp blow out or get damaged.
Are those rms wattage?
Anyways, your subs (if you have two) will double the power of your amp, meaning your amp will be under powering your subs. Nothing will get blown out but will never see their full potential. But if you were to use single sub with your amp then you are more likely see the full potential of the sub and amp.
2 subs=2200 watts is just twice the power of the amp output power!
Jan 06, 2011 | Car Audio & Video
Have a 2000 gmc sierra ext cab pickup and two type R swr-1042d subs and would like to know the best enclosure for the subs to get maximum performance and the best ways to hook up a one channel mono alpine...
it depends on the amp what can it handle. will it do 2 4 or 8 ohm is it 1 ohm stable are the subs dual 2 ohms or dual 4 ohms. 1042s are dual 4 ohm subs so if you wire them both in paralel it will drop both subs into a 2 ohm load for each sub that is pos of one coil to pos of sec coil then pos to pos on amp and same with neg to neg to neg on amp. now if your amp is 1 ohm stable i would do both subs the same way you will get the most power out of the amp. but itll run a littl hot if you dont have adaquate power running to the amp. now i wanna think your alpine amp maybe only 4 ohm stable. i would run both subs like i had said pos to pos then neg to neg now both subs will be a 2 ohm load so what you do to bring it back up to 4 is you run the 2 bridged subs into a series which is pos from one sub to neg of the other sub the remaining pos and neg will run to the amps pos and neg. which will make it into a 4 ohm load. now the last scenereo is your amp is 4 ohm or 2 ohm stable. this is how to wire it to 2 ohms and not 1. take one sub go pos to neg then pos to pos on amp and neg to neg on amp this will make an 8 ohm load with one sub take other sub and do the same neg to pos on sub then pos to pos on amp and neg to neg on amp this will tell amp to run a 2 ohm load. 2 ohms is a good run for these subs if the amp can handle a 2 ohm load. now if you would have given the amp model number i could have looked it up to just give you what you needed but with this short info i gave all possibilities.
Apr 20, 2010 | Alpine Type-R SWR-1042D Car Subwoofer
I intstalled a new hard drive. When I attempt to
Make sure you have a compatible hard drive. They're not all the same.
Dec 08, 2009 | Dell Latitude D600 Notebook
How do i bridge 2-4ohm dvc's to a mono block
If you have a DVC 4ohm speaker, and you are using both voice coils, the amp is seeing a 2ohm load.
If you bridge the amp, you CAN run both subs as long as the amp is Two Ohms Stable.
Wire each subs voice coils in parallel.(Positive to positve, neg to neg.) (2ohms) each.
Then wire the two subs in series.(Neg from amp to neg of sub one, pos of sub one to neg of sub two. then pos of sub two to pos of amp.
If it sounds too hard, leave it as you are already running the amp at two ohms.
Sep 13, 2009 | Car Audio & Video
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
Apr 02, 2009 | JBL PB12 Subwoofer
Connecting a subwoofer to a mono amp that has 2 sets of terminals
ok this gets confusing sometimes. Ok first look to see what ohm your subs are. If you have a dual 4 ohm sub When you run that on sub + to + and - to - then that will make that sub 2 ohm. its different on ohm if the sub is say a 8 ohm then putting the wires that way will bring that sub to 4 ohm. Now lets say you have 2 subs that are dual 4 ohm and wire both of them + to + and - to - and go bridge the amp which would be both wires from sub both + together and both - wired bridge on the amp will make it a 1 ohm to the amp. Please post what ohm your subs are and i can tell you alittle more about it
Oct 21, 2008 | Verge VGA300M Car Audio Amplifier
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
Car Audio & Video Logo
83 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
