Question about Casio Exilim EX-S500 Digital Camera
Problem taking picture out-door
Pictures taken out-door turns out very bright and could hardly see any images. I am using auto focus. How to solve this problem
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
Were they taken in day light? which status is the camera on? Manual, Automate etc..)
Posted on Jul 02, 2008
Brightness of the monitor screen changes when a picture is taken, the final picture looks blurr. Is there any solution?
Are you pressing the shutter button half-way and giving the camera time to lock in the focus before pressing the rest of the way? If not, the good pictures were just luck.
The overall image is out of focus
If Pan focus is being used, the image may be out of focus; use Auto Focus Mode.
Pan focus uses a focus range of several feet, so the image might be blurry but will be captured faster. This could occur in the EX-Z30, EX-Z40, EX-Z50, EX-Z55 and EX-Z57.
If digital zoom was chosen and the image becomes unclear, only use optical zoom, and move closer.
Check the owners manual; hope this helps.
Jan 12, 2011 | Casio EXILIM Digital Camera
Very very bright pictures outside and lines thu the inside ones
Check that the camera is not in night mode or overesposed from menu setting, I think you need the manual. Put it in daylight mode
Apr 09, 2008 | Cameras
Lens won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 07, 2009 | Canon PowerShot S2 IS Digital Camera
There is no image when it is in camera mode but can playback pictures taken before the problem occured. when i take pictures no image in the lcd monitor and no picture taken when i check in playback
Now the A460 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Sep 24, 2009 | Canon PowerShot A460 Digital Camera
Quantaray 70-300
Sounds like the aperture inside the lens is broken. You shuld send it in for service.
Aug 07, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Image problems - samsung L100
You can try a different memory card, but I don't think the problem is memory card, if pictures look scrambled, and colors and brightness are not uniform, that is either a problem with CCD sensor (optic sensor that takes the picture), or logic board.
In either case, this is not an easy repair.
Reset the camera to default settings from camera menu, and try a different memory card, but the camera will probably need to be sent in for repairs.
Jan 02, 2009 | Samsung L100 Digital Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
No picture when its sunny outside colour is distorted inside its a jvc digital cam gr-d33ag
On several camera the ccd is sensitive to bright and causes the images to come out very dark or out of focus because the auto focus sensor is being blinded. Try taking pictures with you back towards the sun and try turning off your flash this some times helps out. I hope this helps you and happy photo taking.
Mar 28, 2008 | Cameras
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
60 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
