To minimize the possibility of electric shock, unplug the dryer from the power supply ... When clothes are taking a long time to dry or do not seem to be drying, the ...Missing: zanussi tc7102w far
? 2:13
https://www.youtube.com/watch?v=ql6_fRRc20c
Dec 14, 2009 - Uploaded by ManageMyLife
Here are common reasons why laundry can take longer to dry than normal. ... my dryer takes too long to dry. i have cleaned it, hose, lint screen, could this has anything to do with ... Dryer Troubleshooting - Not Drying or Taking a Long Time to Dry - Duration: 14:08. ... How Does an Electric Dryer Work?Missing: zanussi tc7102w far
? 14:08
https://www.youtube.com/watch?v=xiqlFX0VRQo
Jun 26, 2012 - Uploaded by Bill Newberry
Why is my Dryer taking too long to dry. How to .... What type of connector shoul
have u check the heating duck that goes to outside it could be blocked or full of lint. u might look inside the dryer and clean the tube that goes to the back of dryer
Always clean filters, if your hose goes up, check for stopped up vent hose (in the attic, happens alot in apts. ). If you have a neighbor behind you who is attached to the same vent going out and you leave your clothes in the dryer and they are dry. His dryer running will make your clothes damp. Have had all of these problems.
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
There is a thermostat inside the machine just inside and top, put your head in and look up. Took my whole machine apart before finding the wire which led to it!! It should be Normally Closed (NC) and cuts the power to the heating element when too hot or broken! Hope this helps.
