Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
INTERMITANT FAULT ON THE LED DISPLAY THE SIMBOL H20 KEEPS APEARING AND THE MACHINE CANNOT FINISH IT CYCLE
  • 4,889 Answers
This is a plumbing error and not a machine error. H20 means "water turned off or valve faulty"
Posted on Jul 15, 2008
H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
Jan 23, 2013 | Washing Machines
Restart off
4.4 Restart Feature
If a fault occurs in the machine, the diagnostic system will detect it. However, instead of displaying
a fault code immediately, the machine will try to restart. If the fault was only of temporary nature,
the machine will restart and finish the cycle. If there is a continuous fault the machine will try to
restart a number of times.
This process could take up to 8 minutes depending on the type of fault. After this, if the machine
still cannot restart, the fault code is displayed and the machine will beep continuously. The number
of retries will depend on the fault that it has detected, however the maximum number or retries for
any one fault is 32 times.
The restart feature is turned on when a machine leaves the factory. For servicing we strongly
recommend that this feature be disabled.
To turn the restart feature on follow the procedures below:
1. Enter diagnostic mode (Refer to Section 4).
2. Press WATER LEVEL DOWN so that the low water level LED is lit.
3. Press POWER to turn the display off (the 5 leftmost wash progress LEDs will be flashing).
4. Press POWER to turn the machine on.
5. The machine can now be tested on any cycle.
To turn the restart feature off, either repeat the steps above or switch off the power to the machine.
The restart feature can be permanently programmed in to the machine's memory. When in
diagnostic mode press and hold ADVANCE down at the same time as pressing WATER LEVEL
DOWN. A long beep will acknowledge the setting has been retained in EEPROM. Press POWER
to retain selection as with size switching. To remove from the permanent memory, repeat the
above procedure.
Note: This feature is designed as a service aid only and should be left on in the customer's
home. To return to normal operation, and to reset the restart feature to the factory setting,
switch the machine off at the wall or disconnect from the mains supply.
4.5 Recycle Feature
The recycle feature, when enabled, will cause the machine to continuously repeat the cycle that
has been selected. At the completion of the spin cycle the machine will power off briefly then
power back up again and will start the cycle programmed.
This feature would be useful to help identify an intermittent problem, and would be best used if the
machine had been taken back to a workshop for service.
To turn the recycle feature on follow the procedures below:
2. Press WATER LEVEL UP so that the Medium water level LED is lit.
3. Press POWER to turn the display off (the 3 rightmost wash progress LEDs will be flashing).
Note: This feature is designed as a service aid only and should be OFF in the customer's
home. To return to normal operation, and to return the recycle feature to the factory
setting, switch the machine off at the wall or disconnect from the mains supply.
Feb 12, 2012 | Fisher and Paykel Fisher & Paykel Washer
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Machine keeps beeping. Filling and emptying with water and H20 is flashing in the digital display
Well error H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose. To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, then the valve will not operate properly.
If you think it is ok then it is quite likely a valve fault, also check the filter built into the valve inlet.
Please post comments for more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Ultima WF860 Front Load Washer
Display periodically flashes H20
The faulot is related to the incoming water supply.
Chaek inlet hose for restriction or low water pressure.
Jan 19, 2010 | Washing Machines
C1 keeps popping up on display during cycle and wont finish. what do i do?
C1 isn't the code, it is a warning that a problem has been detected with the ABS system.
Apr 26, 2009 | Washing Machines
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Flashing H20
h20 means no water is getting to the machine. check your washing machine taps are on and water getting to the machine and the fill hose is not kinked.
Jan 26, 2009 | Washing Machines
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
682 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
