I have 2 liteon external dvd burners and they are less than a month old. Sometimes they may burn 3 discs other times you can't even get one copy!!!!
    Genius:
  • 2,785 Answers
Plz try by reinstalling your burning software if the problem is not solved then you should ask for replacement from the vendor
Posted on Jul 02, 2008
Just purchased a liteon dvd burner.When I try to burn copy of dvd movie; the message I get states that the movie is copyguarded. My old dvd burner has no problem copying copyguarded movies using...
you might need a program like AnyDvd which removes copywright from a dvd and allows you to burn it without any restrictions to be able to play the dvd in australia
hope this helps
Dec 13, 2010 | Lite On LITEON 16X DVD BLACK OEM (Come...
Cd/dvd drive stopped working - matshita dvd-ram uj-861h ata devic
Hmmmm see try cleaning the temporary files which are stored ...I mean files ready to burn to dvd .. You can find them when u click dvd drive with out any disc in it.
Create a new user account and then remove all the burning software and then reinstall it.
If still doesnt work tough luck dear .. Reformat the hdd might help.
Mar 31, 2010 | Panasonic Computers & Internet
Dvd burner won't burn!
do you still have the software for your external dvd...if so...uninstall it....now start all over like it is brand new...reinstall and reconnect the dvd....this shoud do the trick...
FYI
all dvd movie take 2-3 hrs to burn (some even 4 hrs..depends on the lenght)...and for the future never just turn off any data transfering devices....not even your pc when windows is updating....
May 25, 2009 | Lite On LITEON USB 2.0 EXTERNAL 52X32X52...
Burned DVD video couldn't play
are the videos you are rying to burn store bought
Mar 25, 2009 | Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
How to tell
Burner software will check DVD-RW disk has suffient free disk space, compressed or not. Then you only select a bit less then maximum. Change disk and repeat until all chosen files are copied.
May 16, 2008 | Acer Aspire 3680 Laptop
Half-way burn?
Runa thorough virus scan and if nothing shows there, do a system restore...accordianman
Feb 28, 2008 | Sony (DRU720A) DVD±RW Dual Layer...
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Hp 740e not reading blank dvd discs
Don't wanna sound like a Doomsayer but I think it has burned its last burn...
Try to clean it first, if it still doesn't work, then it is time for a new one.
Had a similar experience and we found out that the drive had conked out.
Feb 03, 2008 | HP EXT DVD BURN HP|DVD740E LS BK R...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
