Question about Belkin (F5D5231-4) Router
LEDs out.  If power cable is pulled and replaced or if the plug is jiggled the lights flicker for a few seconds then go out.
    Brigadier General:
  • 6,966 Answers
Based on your post of intermittent power (more often out) is indicative of a cold solder or loose connection specifically with the jack at the back of the unit. They are often soldered to the main board and only two (2) connection points. Corrective measure entails opening the covers exposing the bottom of the board and re-soldering (with a little dab of soldering lead).
In some case, it could be the plug that has a problem and would require generic replacement. The polarity has to be observed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 02, 2008
The wireless light will not come on belkin router
Try pulling the power cable for 15 seconds on the modem, then plug it back up and then wait for all of the lights to come back on. Then pull the power cable on the router for 15 seconds, plug it back up. Also you have a reset switch on the back of the router that may help if the power cycling doesn't work. Hope this helps fix your problem-good luck...
Mar 14, 2012 | Belkin F5D8236-4 Router
Pls how can i reset my audiocode mp-118 back to factory deffault. because i have try to look for the latest firmware on www.audiocode.com in order to upgrade it. unfortunately i didnt find any.
First of all unplug the network cable.
Then take a pin or a needle and insert it into the pin whole which is intended for reset. Insert the pin inside the pin whole and press at least for 6 seconds. All the LEDs (Light emitting diodes) or the tiny lights will glow brighter while the reset button is being pressed by the pin. The device will reset. After reset the red LED may start to blink bright.Be careful and be patient as all the LEDs are normal before you plug in the network cable.
Good Luck!
Jul 26, 2010 | AudioCodes MediaPack MP-118-FXS Router...
We have a 3CR858-91 3com router and nobody knows it's administration password. I have tried to reset it to the factory defaults using a RJ45 cable (DSL port to LAN port connected) but it does't work (even...
I have same problem. So the solutions is (in my particular case), when you done everything as it written in the reseting instruction. You face blinking LAN/WAN ports and no any activity with Alert LED. After 30 second or even 1 min (i don't relly know do you need to wait or not), i disconnected LAN/WAN ports and connected it again without repowering. Then Alert LED starts to blink slowly every 2 second. After re-applying power it was reseted.
Mar 29, 2010 | 3Com 3CR858-91 Office Connect Cable/DSL...
My linksys wrt54g was working fine. WE moved my computer and it stopped working. I reinstalled the driver and when it came to the point of trying to recognize if the router was connected it could not find...
The lights on your router indicate a firmware problem. To fix it, you need to hard reset the router. Press the reset button at the back of the router for 30 seconds then unplug the power. Wait for a minute before you plug it back in. Check the lights again. That should fix it.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Asus Router Offline
hello!
-- can you get online if you connect your computer directly to your modem?
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Actiontec wireless router
This is a Wireless Gateway not a router. Although the Actiontec website says that it uses NAT firewall like a router would.
If you do not get any green lights this usually means the wireless gateway is broken. Try plugging it into power but not the modem. Wait a few seconds. Are there any green lights?
If so, then the gateway is not configured correctly to work with your modem. You may have a smart modem. Call your ISP, for help.
If not, then it is probably a bad gateway. You can try to connect to the configuration web page that comes with the gateway. OR Power on the unit while holding down the Reset button for a minute. This will reset it to factory defaults.
ActionTec
Nov 20, 2007 | Actiontec (GT704WG) Router
Belkin (F5D5231-4) Router Logo
41 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
