Question about Hoover Washing Machines
Hoover performa plus ppa 136 Water not draining, light flashing
    Sergeant:
  • 225 Answers
Hi.
I'd suggest checking the filter for blockages, as per the instruction manual. (Beware- water will probably come out!!!)
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please add a comment with any extra info you have and I will try to think of comething else.
Thanks, D
Posted on Jul 02, 2008
When I switch on the On/Off button the machine trips the mains electricity. It is a Hoover Performa 1100 Washing Machine
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 09, 2011 | Hoover Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Where are carbon brushes located inside Hoover Performa Plus PPA 146-80 and how easy is it to remove them and replace?
The carbon brushes are part of the drive motor , early machines had replaceable ones ,but on many modern machines they are not replaceable , it depends on which motor has been fitted . you need to know if / why they need replacing anyway before attempting same.
Nov 08, 2009 | Washing Machines
How to work the hoover performa 1100 washer dryer
My Hoover Performa 1100 does not drain the water therefore it does not open. Can anyone help please?
May 15, 2009 | Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
hi,
unplug it
try and take the drain hose out of the wall drain and get it as near to the floor as possible into a bucket, maybe let it hang out the door on the ground, gravity should let the water drain out, If its a new type it may not work though but you can try that.
good luck
J
Jul 16, 2008 | Washing Machines
My Hoover VHD8142 stops whilst draining then the timer saver light and the 1200 lights flash. The machine does not drain away all the water. I cannot find what these lights flashing means in the manual,...
I've just had exactly the same problem with the same model. Unlikely as it may sound, it's the heating element. Mine has just been replaced and everything is now working perfectly.
Jun 05, 2008 | Hoover Washing Machines
Washing Machines Logo
227 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
