Question about Apple iPhone Smartphone
Good day everybody. I have a problem with my iPhone, I was surfing internet while the battery was too law and it suddenly goes off by itself, i thought that was a battery issue and i have to recharge it. but after i went home i tried many times to charge it but it completely dead I tried wall socket i tried USB i tried in my car everything it is completely black the screen never went on please help me out do i have to press something. I'm new at iphone :(
    Top Expert:
  • Apple Master
  • 12,962 Answers
Your battery has gone to battery heaven - get a new one.
Posted on Jun 17, 2017
sgregg
  • 133 Answers
SOURCE: iPhone Battery power Problems
No, my cousin has one and it works fine, but remember if your battery isnt fully discharged it wont last as long. before you go just charging it all the time you should everynow and then let it run out before you recharge it.
Posted on Aug 02, 2007
Datgirlcoach
  • 5 Answers
SOURCE: iphone dead
Ok. There is a nasty rumor that only the update affects iphones that are unlocked. This is very untrue.  Whenever you try to use almost every accessory that was made for an iphone, You will encounter this problem. As well, most of these products when you plug in your iphone will cause a message to pop up stating that the device is not compatible with an iphone. and will ask you if you want to put the phone into airplane mode. Though this option is available you now have a device trying to charge, and use an incompatible device. Hence the black out. I went through those myself with a ipod dock alarm clock. Unfortunately, unlocking your phone, voids your warranty.. I will still try to to find a way to revive you iBrick but the outlook is bleak. Sorry.
Posted on Dec 29, 2008
SOURCE: Iphone, not reading sim, not connecting of itunes...
another way to restore it would be to turn the device off, then hold down the power button and plug it into your cpu still holding the home button and it should show up in itunes
Posted on May 05, 2009
SOURCE: my iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
Posted on Jul 28, 2009
NEXTLAB
  • 58 Answers
SOURCE: iphone wont turn on!!!
Hi slondon83,
I believe you will have to reflash your device, using the restore feature on iTunes and the CFU mode in you iPhone.
To restore your iPhone, you will have to enter to CFU mode:
1. turn off your phone, or wait it get turned off by itself.
2. press and hold the power button for exactly 3 seconds.
3. whithout leaving the power button, press the HOME button for another 10 seconds exactly.
4. after 10 seconds leave the power button but still, keep the HOME button pressed.
try all these steps, of course, while you iPhone is connected to your computer with the USB cable and the iTunes software is on.
you might be able to do it with this method too:
good luck!
Posted on Aug 29, 2009
My iphone 4S all of sudden won't charge on my ihome. It worked the day before and my wife's iphone works. It says device not supported. Any Thoughts?
Either the battery needs changing or the charging circuitry in the phone itself goes bad. As another option, you can try power the device off and wait a few minutes before turning it back on. Hopefully that will reset the phone and it will work afterwork.
Jan 13, 2015 | Cell Phones
Tip
How To Save Battery On Your iPhone or iPod Touch
<p><span><span> </span>Is your iPhone or iPod Touch's battery level always depleting quickly? Do you not have enough juice to get you through the day? Here are some quick tips to conserve your battery life and help you get through the day while you are Facebooking, sending texts, and calling.</span><br /> <p><span><span> </span>First, lets make sure you can monitor your batter level. This is how you will turn on the percentage of battery display.</span><br /> <p><span>1.<span> </span></span><span>Go to your home-screen.</span><br /> <p><span>2.<span> </span></span><span>Open up the Settings App.</span><br /> <p><span>3.<span> </span></span><span>Tap General then Usage</span><br /> <p><span>4.<span> </span></span><span>Where it says battery percentage, make sure the switch is in the on position.</span><br /> <p><span><span> </span>Now that you can monitor your battery life, here are a few things you should continually do to save battery.</span><br /> <p><span>&bull;<span> </span></span><span>Don't keep multiple apps running if you don't have to. iPhones and iPod Touches have multitasking to run multiple apps at once, but this can use a lot of battery. To delete tasks, double tap the home button and then hold down an icon at the bottom of the screen. Once the apps begin to wiggle, tap the X by the app to stop the task (note: this won't delete the app, it will only stop it from running).</span><br /> <p><span>&bull;<span> </span></span><span>Another battery saving setting is not fetching email quite as often, I mean, do you really need to check your email every 15 minutes or hour? Fetching data uses a lot of battery, to disable or not as frequently fetch for data, go to the Settings app again. Go to Mail, Contacts, Calendars then Fetch New Data and set it to Manually so to check email, go to the email app and click the refresh button.</span><br /> <p><span>&bull;<span> </span></span><span>Your iPhone has an adjustable brightness, and a higher brightness wastes more battery, to change the brightness: go to your Settings app. Go to Brightness and turn your brightness down. You don't necessarily need to turn it all the way down(especially when you are in bright lighting conditions, kind of ironic that you need higher brightnesses in brighter environments), but if you are in a pitch black room, then there is no reason to have the brightness above the minimum level.</span><br /> <p><span>&bull;<span> </span></span><span>Another good habit is turning off bluetooth and wifi when you are not using them, to do this, go to your Settings app again. Go to Wi-Fi and turn of wifi. To turn of bluetooth, go to General then Bluetooth and turn it off.</span><br /> <p><span>&bull;<span> </span></span><span>If you don't necessarily use an app a lot or at all, turn off Push Notifications. To do this scroll all the way down on your Settings app, and choose that particular app. This will only be useful on an app that gets information from the internet. In the particular app that you chose, usually there will be a Push Notifications option, and you can disable this, this will help your battery because your iPhone constantly tries to search for data with these on. Also, when installing apps, you can disable this then.</span><br /> <p><span>&bull;<span> </span></span><span>Another good way to save battery (iPhone only) is to switch from the 3g(fast internet)radio to Edge(slower internet) radio. On the iPhone, you have twice as much battery with Edge radio. To change between the two, go to your Settings app once again. Go to General then Network and where it says Enable 3g switch it to off. You can/should do this when you aren't heavily surfing the internet, checking Facebook, or downloading apps. Don't use this with apps that require heavy internet usage.</span><br /> <p><span>&bull;<span> </span></span><span>One final tip to conserve battery is changing the amount of time until the iPhone/iPod Touch goes into sleep mode. If you forget to put it in sleep mode, it will stay on and waste battery in your pocket, etc. To change the amount of time to save battery, go to your Settings app again. Go to General then Auto-Lock and change it to something short such as 1 or 2 minutes.</span><br /> <p><span>These tips will significantly prolong your battery, use them to your advantage.</span><br />
on Apr 19, 2011 | Apple iPhone Smartphone
My 8GB Iphone randomly goes to black screen with silver Apple logo during use then takes anywhere from 5 to 30 minutes to reboot or something. This happens quite often now no matter what the phone is being...
Well, it seems to me it's more likely to be a problem with the hardware of your phone. Most likely you need to take it to apple for repair or replacement.
A couple of things you can try tho....are first, to do a restore on your iPhone...if it is not a hardware problem, it could be the iPhone software itself. Do a restore, but I would try not restoring from a back up. Get the latest version of the iPhone software and restore the phone from scratch, and then sync your library.
Another thing it might be, could be the battery. There are lots of instructions online about how to change the battery, but it all depends on how brave you are when it comes to ripping apart your iPhone.
I think you may be a bit stuck and may have to take it to Apple for repair.
Good Luck
May 26, 2011 | Apple iPhone 3G Black Smartphone
I was surfing on Facebook and my iphone suddenly turned of by itself. It had some charge!
That will happen sometimes for no reason... just restart the phone. If it begins to do that very often then you should return it to your phone provider for service.
heatman101
May 17, 2011 | Apple iPhone 3G
Hi, I surf for couple of years now. Is there an iphone app for surfers?
Sure is! It's called 'Surf Report'.Take the mystery out of checking the surf with the Oakley Surf Report powered by Surfline. Check the surf height, swell direction, and tide. Monitor the weather. View a 2-day forecast. You'll know exactly where to go when there's a low tide, with an epic SSW swell, and an onshore breeze. And you can do it all from the comfort of your iPhone or iPod.
Sep 06, 2010 | iPhone Apps
Battery life less than 12 hours; Wifi says "UNABLE TO CONNECT"
This is a really good article that will take you step by step through the settings that will best optimize your battery life. And if this doesn't help you should make an appointment at your local Apple store, they are always very helpful (at least in my experience).
http://www.apple.com/batteries/iphone.html About iPhone BatteriesLearn how to maximize the lifespan and battery life of your iPhone.
Nov 09, 2009 | Apple iPhone 3G
Iphone wont turn on
hey mate.. what you need is,
Turn on your itunes, and when the iphone is off, press the round button (home button) for 15seconds and without releasing the button, plug it in your computer with itunes running.
Once you see the startup of the iphone, release the home button.
Then after that click shift on the computer to restore to the previous version.
good luck..
Sep 10, 2009 | Apple iPhone Smartphone
Is it possible to take out battery of iphone 3g? phone hang up
actually there is no batttery on the iphone to remove. The battery is hard wired to the phone board itself. However if you hold down the home key AND the power key down at the same time for about 15 seconds it resets your phone as if you removed and reinserted the battery.
May 02, 2009 | Apple iPhone Smartphone
Unknown error 1024 on Iphone
add me to your msn and i will talk you through the steps to solve your problem.
add me Rightpricedelectrical@googlemail.com
regards nick
Apr 20, 2008 | Apple iPhone Smartphone
Ap 700 reboot suddenly
Device setting themselves on their own to default?  Sometimes power surges, thunderstorms causes all of these. Reconfigure devices and try to buy surge protector.
Oct 18, 2007 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Apple iPhone Smartphone Logo
142 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
