Question about Nikon COOLPIX Cameras
Broken screen I have a cracked screen, how I don't know - everything else works fine! What are my options for replacing as I expect sending it back to Nikon would be too expensive. Many thanks
I bought another camera on ebay - a Canon Ixus 400 for less than it would probably cost me to have repaired!
Regards
Posted on Jul 02, 2008
How to fix Samsung S4 cracked screen?
http://www.ifixit.com/Guide/Samsung+Galaxy+S4+Cracked+Front+Glass+Replacement/21843
Apr 24, 2014 | Samsung i9500 Galaxy S4 16GB Unlocked...
Toshiba, broken screen
If the screen is physically broken (cracked) it's usually NOT covered under the warranty.
You can check your coverage HERE.
May 25, 2010 | Toshiba Satellite L505DES5025 Notebook
Screen says "unable to initalise" . It will send a fax and will phone on the speaker phone but cannot copy or receive a fax.
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Oct 26, 2009 | Brother MFC-620CN multifunction Color...
Broken screen on sidekick 3
To replace the cracked screen follow the guide below. It is fairly easy to do and runs about 30 dollars from ebay.
Here is a guide for it
Sidekick 3 LCD Screen Replacement
New Sidekick 3 LCD Screens for Sale
Sep 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
I dropped my 32" Samsung LCD LNS3241D and the screen cracked help
i will buy th broken tv, i have the same tv but with power and inverter problems. let me know.
thank you
Jan 15, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
LCD screen has gone on nokia 2610.. needs replacing. Everything else works fine
Here is a quick guide that will show how to replace the LCD screen. They are only 20 dollers or so on ebay. It is a pretty easy process.
http://www.howtofixmyphone.com/how-to-replace-a-cracked-or-broken-nokia-2610-lcd-screen/179/
Good luck.
Sep 22, 2008 | Cell Phones
Kenmore Elite ET3
The plastic casing (tub shell) around the stainless spin basket should not become worn unless the spin basket is hitting the outer shell. From my past experience, this is usually caused by a cracked or broken spin basket support (spider) arm on the back of the spin basket, or a shot tub bearing (which is also behind the spin basket). The bearing is actually part of the rear tub shell and is molded into the plastic. It cannot be replaced separately and requires the replacmeent of the shell.
If the spin basket supports become broken, the basket becomes off balance and rubs against the outer shell. This results in excessive vibration, which may be the reason why the support shocks were broken. No...this is not normally expected. Unfortnately, this is not a simple or inexpensive repair, either. If you have a service plan, or warranty coverage, I would recommend pursuing that as a repair option. If you wish to repair this yourself, I can post a link for you to follow, but it is expensive. This will usually require the replacement of the following parts:
Spin Basket
Rear Tub Shell (if bearing is bad)
Front Tub Shell (if spin basket caused significant damage)
Support Shocks (I would recommend replacing all 4)
Optional:
Drive Belt Pulley (can become warped or bent)
Drive Belt (if showing signs of wear)
Rubber Door Bellow (if vibration as caused damage to the rubber)
You can go to searspartsdirect.com and type in your model number to get prices for everything if you like. Everything can be found under the "Tub and Basket Parts" heading, with the exception of the rubber door bellow. It can be located under the "Door and Latch Parts" heading.
I know none of this sounds like positive news, but I do hope you find some of this information helpful. Let me know if you need further assistance.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Broken lcd screen
the LCD screen can be replaced easily. The cost of changing, depends on the place where you live.
Jul 30, 2008 | Nikon Coolpix S50 Digital Camera
Cameras Logo
46 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
