Question about Panasonic Home Theater System System
Sc-pt760 "chgr err"
Just got my Panasonic scpt760 out of the box. I turned it on and it made a strange noise for a while then told me "chgr error" It then would not let me do anything with the remote. The manual says turn it on and off and if problem does not fix itself contact the dealer. Any way to fix this?????
  • 6 more comments
  • PissedWBB Jul 03, 2008
    Before
  • jpmorgan300 Jul 27, 2008
    I have the same problem on my pt660. It was working for about a week then this just happened one morning
  • cribbshockey Aug 02, 2008
    I have the same problem...have been delivered 2 units...same issue with both of them, any answers?
  • jmcnally1953 Oct 04, 2008
    I have the same problem.  I just bought mine yesterday.  I tried the "fix" on page 35 (ie Press the power button etc) but still won't work.  I plugged everything in AFTER I had everything else hooked up as directed in the manual.  I will try to contact Panasonic today, but what a bummer.
  • chas_t8888 Oct 17, 2008
    I have the same problem. Just received it and and getting this error message. What can I do to fix it? I really don't want to send it back.
  • WarioHussein May 11, 2010
    Did you plug everything else in before or after you plugged the main unit in?
  • Ralph Oldman
    Ralph Oldman Oct 30, 2013
    For panasonic sc-pt760, if the DVD player is busted, you can't access the option to switch to Digital in. With Digital in, you can still use the unit as a sound system by feeding it through the optical input from your TV. but, the trick, You can't access the switch menu without an ipod. For some reason, you can switch from an Ipod to your D-in. You can't switch out of AM/FM to d-in as it tries to access the broken DVD first.
  • Ralph Oldman
    New Friend:
Posted on Oct 30, 2013
4 Suggested Answers
  • 25 Answers
SOURCE: I have a err code "chgr err" on my panasonic sc-pt960.
This would indicate a CD/DVD Changer Error.
The system thinks there is a stuck disc or other wierd problem with the CD/DVD changer.
Unfortunately these issues are rather hard to fix, due to the way the changers work.
Opening these units isn't that hard, however fixing an issue with the changer is very difficult and is best left for a specialist.
You may need to contact a local Panasonic repairer to get this one fixed.
Use the link below (if you are in the US) and enter your model number and ZIP code to locate your nearest repairer.
http://www2.panasonic.com/consumer-electronics/support/?cm_sp=Homepage%20Support-_-Header%20Support-_-Support%20For%20Customers%20Link
Best of luck, and sorry that I could not be of much more help than this.
Posted on Jun 22, 2009
SOURCE: I have an SC-PT760 that the only thing that works
I wish I had a solution for you. Mine just did the same thing (it's only a year old). I called into Panasonic, and they very briskly told me all they could do was give me the number of a local repair man. I called them, and was told it would cost about $250 to fix it.
Posted on Dec 15, 2009
moz205
  • 80 Answers
SOURCE: panasonic sc-pt760
LOL if you just paid good honest hard earned cash for it i would certainly take it back. You might get a few freebies in the process. If you never broke it, Dont try and fix it because you will be held responsible for any damage they deem fit to blame you for.
Posted on Oct 25, 2008
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
May 09, 2011 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I only use it for surround sound but I cannot use it for...
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Jul 05, 2010 | Panasonic SC-PT960 Theater System with...
Chgr error on my panasonic pt760 discs will not eject
Lock123 already solved my problem great service no wait time your site is the best one out
Jan 24, 2010 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SC-PT760 that won't turn on!
if it was stored in a damp area it may take awhile for it to turn on until it dries out.most units have a dew protection sensor on them
Jan 17, 2010 | Panasonic SC-PT770 Theater System with...
I have an SC-PT760 that the only thing that works is the stereo.The on/off button on main unit doesnt work. Keeps saying ''chgr err'' and makes clicking sound. I just found out it was discontinued. I see...
Dec 12, 2009 | Panasonic Audio Players & Recorders
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
Chgr err message on display. what does this
IT MEAMS THE MECHANISM IS MISSALIGNED.NEED TO SEND IT IN FOR ALLIGNMENT
Jul 25, 2009 | Panasonic Audio Players & Recorders
Jun 22, 2009 | Panasonic SC-PT960 Theater System with...
Chgr err on panasonic scpt760
what i am supposed to do if i get chgr erro on panasonic scpt 760 receiver
Nov 04, 2008 | Audio Players & Recorders
Panasonic sc-pt760
Oct 17, 2008 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
751 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
