Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Adding hard drive to network
I have a network hard drive which i have connected to the router via a network cable. When my laptop is connected by network cable i am able to access the mapped hard drive, when my laptop is wireless accessing the network i am unable to connect to the hard drive.
  • phil2227 Jul 02, 2008
    Searched IP address then comes up with error message -34 unable to connect. then i plug in the network cable and it works fine.
  • 611 Answers
Search the ip address which you give to the secong hard drive.
Posted on Jul 02, 2008
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
Dec 11, 2010 | D-Link Computers & Internet
I have an Iomega home network hard drive 1TB, but for some reason my xbox 360 will not pick it up. Does the drive need formatting to FAT32? How should i connect it to the xbox?
This box has to be connected via USB to a PC ...OR... via an Ethernet cable to a piece of network hardware, such as a router/switch/hub.
I recommend the Ethernet cable route.
Once connected, and assuming your router will give the media drive an IP address (you can check this from your router's admin page) then you should be able to browse to the hard drive from the XBox.
Apr 30, 2010 | Computers & Internet
How can i connect the laptop to the router
First, buy a CAT5 cable from a computer store, then connect it from the laptop to the router.
Feb 21, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
I can see another network but not my network
Connect your computer to the router via an ethernet cable and log into the router's admin interface. Make sure that all of the wireless settings are set up correctly. If they are, try changing the mode between G and N or any other choices. Also try and change the frequency to make sure there is no interference.
Aug 21, 2009 | Samsung NC10-14GW Notebook
Can usb substitute for the ethernet connection?
Perhaps buy one on eBay (possibly $60) and pull it's interface circuit board, to replace your bad one:
Apr 10, 2008 | Ximeta NetDisk (NOWWL) 160 GB Hard Drive
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Adding an external hard drive to a home wireless network
Try setting configuring the privledges setting. Make sure there the network setting is correct, and make sure all user accounts have admin access to network
Oct 06, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
126 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
