Question about Canon LASER SHOT LBP-3000 Printer
LBP 3000 if a strip of blank line appears from the top to the bottom of the page after you printed, does that mean that the toner is out? there is no indicator, unlike colored printers. if we shake it, it comes out ok. then after about 10 pages, the blank (no print lines) come out again. is it even ok to shake the cartridge?
  • jeanstew Sep 07, 2008
    I have a black stripe down the left hand side of my paper, I had the cartridge refilled, at first no problems, but now this black stripe, I have taken out the cartridge and cleaned inside but there was no excess ink power inside or on the rollers. I have also shaken the cartridge, but the problem is still the same.
    If you know what the problem is please could you let me know.
    As at the moment I can not use the printer, as it is.
  • Anonymous Oct 25, 2008
Hi iwant just printer driver for canonlbp3000 thankyou
Posted on Nov 09, 2008
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
canon 2900 printer first time refilling completed but print not coming wht is problem
Sep 12, 2012 | Canon LASER SHOT LBP-2900 Printer
How many copies print in one cartage of canon2900b laser printer?
Canon laser toner CRG703 for use with LBP 2900/3000. Page yield 2,000.
Jul 07, 2011 | Canon LASER SHOT LBP-2900 Printer
I am getting a blank stripe top to bottom on every printed page
You write "I am getting a blank stripe top to bottom on every printed page". You didn't say copy or scanned pages. Change the toner cartridge.
Feb 04, 2011 | HP LaserJet 3050 All-In-One Printer
I have a printer Canon LASER SHOT LBP 1210 but i can't set up page size Legal thats mean 8.5"x 14.00". Would u pls give me solution how can I get print in the legal size print.
I am Canon LBP 1210 User. canon LBP 1210 laserjet printer not supporting legal size printing. When I give a legal size page printing, there is no response from the printer.Please give a solution.
Aug 22, 2010 | Canon LASER SHOT LBP-3000 Printer
How to print legal paper in 1210 printer
canon lbp 1210 printers
has a probleam a legal page setting
plese answerer legal page setting
May 11, 2010 | Canon LASER SHOT LBP-3000 Printer
Horizontal strip of area is not being printed
May be the problem with laser drive and out of toner. When it happen, shake toner cartridge and replace it. The white strip disappear or not. Please reconfirm. Thanks.
Feb 11, 2010 | Canon LASER SHOT LBP-2900 Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
HP Laser Jet 2840 Printer
If it's scan and copy only and not when you send a job from the computer your solution is easy to remedy. Try going into the menu located on the printer to info menu. Scroll down to conguration page and click the check button. When the printer prints, if the line is not on the page you simply have ink or white-out on the scan glass for the ADF (auto doc feeder).
To clean the ADF glass, lift the top lid to expose the glass. There are two peices, 1 large full size and one strip peice. If your getting the line when using the auto feeder (without lifting top) pay close attention to the strip of glass. When a document is auto-fed it moves the original past the strip of glass. A dot (pen mark or white-out) will appear as a line on your final copy.
Clean well with windex or similar glass cleaner. PUT THE CLEANER ON THE RAG THEN THE RAG TO THE GLASS. Don't spray the glass as it's easy to get it into cracks where to don't want it to fall on an electronic part or board below the glass edges. While you at it, clean all the glass.
Test by making a copy of a "BLANK" sheet of paper with one small line to give you postion clues. First by putting it on the glass. Clean everywhere on the large glass that shows a mark on the page (except the one you purposely put there). The mark will help you locate where to clean. (example - 1" below and 2" over from your intentional mark) It also helps you identify top of page from bottom.
Once that is done do the same thing using the original in the ADF. Simply measure in from the edge of the page on the copy and find the corresponding spot on the small strip of glass.
IF YOU SHOULD BE GETTING THE LINE IN ALL FUNCTIONS, PRINT, COPY MANUALLY, AND COPY WITH ADF. Check the toner cartridge, most likely black for damage on the cartidge drum. The cartridge drum can be quickly viewed by flipping the shutter open (the part with the HP logo and part number printed on it). If there is a line, replace the cartridge.
Hope that helps you. If so hit it with a FIXYA!
Aug 30, 2008 | HP LaserJet 2840 Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Canon LASER SHOT LBP-3000 Printer Logo
280 people viewed this question
old marine
old marine
